A-body K-member #2465598
03/13/18 01:27 AM
03/13/18 01:27 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Was taking a '68 GTS apart (not mine) in the last few days. The k-member in this car (probably a mid-late May 1968 build - no fender tag, but the car is #s matching) is quite different than my original (Aug. 28, 1967 SPD). It has the tabs for the late sway bar bracket bar and is cut open on the underside like the 73-up k-member. The car has the correct motor mounts and sway bar. When did the K-member change? Rhino???
Re: A-body K-member [Re: Jim_Lusk] #2465647
03/13/18 08:15 AM
03/13/18 08:15 AM
western PA
stevet340 Offline
stevet340  Offline
western PA
Pictures would be helpful. I don't quite understand it when you say it has tabs? Are you talking about the lower control arm tabs? The sway bar bushing/bracket assembly that the sway bar goes through bolts to holes on the front of the K-member, two holes/bolts per bracket, two brackets. The K-member should be solid underneath, they didn't change much if at all in appearance until 1970 when the coin/washer was tack welded to 340 K-members. It should have a Julian calendar number stamped on the K-member somewhere to confirm when the K-member was made. Find the number and you will have your answer.
Re: A-body K-member [Re: Jim_Lusk] #2465667
03/13/18 10:26 AM
03/13/18 10:26 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
It's a biscuit motor mount K but with 73-76 kmember provisions? Like the top stamping is 68-72 but the bottom is 73-76?
I've seen one in a 72 abody in person. I was thinking it was a transitional thing. I've seen pics of one someone had loose too.
IIRC, some 69 Bbody Kmembers come out like this too with 69 tops and 70 bottoms.
Now I wonder if the one in that 68 you are working on is a factory replacement part. Some replacement parts have multi year feature so one part number can supercede two or more part numbers. BUT any original car with pass through 73-76 sway bar would have spool motor mounts.
I think the kmember got replaced at one and the doner was one of the rare 72 cars that had that transitional Kmember. Just my guess.
Re: A-body K-member [Re: Jim_Lusk] #2466171
03/14/18 01:32 AM
03/14/18 01:32 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
We have an idea that the SPD was some time in May 1968 (going by the GTS registry and the few SPDs listed). The K-member appears to have been in the car a long time, but the strut rod bushings have been replaced.
I'm of the same opinion as you Steve. We'll know when we get the engine off the K-member and get it more cleaned up. The fenders appear to be original, but the hood has a part number painted on the underside.
Here's a pic showing one of the tabs. I didn't get a pic of the underside, though.
Re: A-body K-member [Re: Jim_Lusk] #2466371
03/14/18 02:17 PM
03/14/18 02:17 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I am pretty sure my k-frame ('68 BB) was replaced somewhere along the car's life, along with the upper control arms. All three were a light grey color and not the usual black. Never looked for that tab, need to take a look when I get home. Also never did bother to take a look at date code on the k-frame while it was out. I was just happy it wasnt dented and was really clean.
Re: A-body K-member [Re: Jim_Lusk] #2466491
03/14/18 05:29 PM
03/14/18 05:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Jim, That would be way to early for a transitional Xmemeber.
Re: A-body K-member [Re: JohnRR] #2466736
03/15/18 01:35 AM
03/15/18 01:35 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
That's what I'm thinking. It's out of a ROUGH GTS convertible...
Re: A-body K-member [Re: Jim_Lusk] #2468637
03/19/18 04:21 PM
03/19/18 04:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
My 5/69 GTS has a full bottom K in it, that changeover of the swaybar didn't happen till model year 73 so the earliest you would see a changeover K would be sometime in the 72 model year. My Feb 69 Bee didn't have the changeover K, I think they started to show near the end of march.
