Re: A-body K-member
[Re: Jim_Lusk]
#2465667
03/13/18 10:26 AM
03/13/18 10:26 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
It's a biscuit motor mount K but with 73-76 kmember provisions? Like the top stamping is 68-72 but the bottom is 73-76?
I've seen one in a 72 abody in person. I was thinking it was a transitional thing. I've seen pics of one someone had loose too.
IIRC, some 69 Bbody Kmembers come out like this too with 69 tops and 70 bottoms.
Now I wonder if the one in that 68 you are working on is a factory replacement part. Some replacement parts have multi year feature so one part number can supercede two or more part numbers. BUT any original car with pass through 73-76 sway bar would have spool motor mounts.
I think the kmember got replaced at one and the doner was one of the rare 72 cars that had that transitional Kmember. Just my guess.
Re: A-body K-member
[Re: Jim_Lusk]
#2466491
03/14/18 05:29 PM
03/14/18 05:29 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Jim, That would be way to early for a transitional Xmemeber.
Re: A-body K-member
[Re: JohnRR]
#2466736
03/15/18 01:35 AM
03/15/18 01:35 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Jim, That would be way to early for a transitional Xmemeber. That's what I'm thinking. It's out of a ROUGH GTS convertible...
Re: A-body K-member
[Re: Jim_Lusk]
#2468637
03/19/18 04:21 PM
03/19/18 04:21 PM
JohnRR
U.S.S.A.
Jim, That would be way to early for a transitional Xmemeber. That's what I'm thinking. It's out of a ROUGH GTS convertible... My 5/69 GTS has a full bottom K in it, that changeover of the swaybar didn't happen till model year 73 so the earliest you would see a changeover K would be sometime in the 72 model year. My Feb 69 Bee didn't have the changeover K, I think they started to show near the end of march.
