Page 2 of 3 1 2 3
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2458260
02/27/18 08:27 AM
02/27/18 08:27 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
fenders are the same...I have an '85 and an '88 fender on my '91. The '91 grill will bolt right in place. My grill was busted, so I put a grill from my '88 on with some tweaks.
great score on both trucks.
1981 Dodge D150 360 auto
Re: Scored a 12-valve... UPDATE! [Re: basketcase] #2458275
02/27/18 10:35 AM
02/27/18 10:35 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That's not what the guy told me that sold me the crew cab dually above. It must be the core support then, I know they are different for a Cummins... shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2458544
02/27/18 07:43 PM
02/27/18 07:43 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
yes...the diesels have a different core support, but the rest of the sheet metal is the same.
Re: Scored a 12-valve... UPDATE! [Re: basketcase] #2458579
02/27/18 09:29 PM
02/27/18 09:29 PM
Bowling Green KY / Nashville, ...
300by500 Offline OP
300by500  Offline OP
Core supports on the 1989 to mid-1991 Cummins non-intercooled trucks are the same as gassers, the 91-1/2 and later intercooled trucks are different.
Core supports '81-'85 are the same, from '86-'93 the headlights are in a slightly different location.
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2458632
02/27/18 11:48 PM
02/27/18 11:48 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That makes sense because my dually is an 85. up
A-Body's RULE!
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2459041
02/28/18 07:48 PM
02/28/18 07:48 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Love these things. My son acquired a '93 W250 extended cab last summer for $3500
During tear-down
Coming along...
Re: Scored a 12-valve... UPDATE! [Re: 70Duster440] #2459166
02/28/18 11:56 PM
02/28/18 11:56 PM
300by500 Offline OP
300by500  Offline OP
During tear-down
Coming along...
That was a smokin' hot deal for a 4X4, and it looks great! in my opinion they look so much better without all that rubber trim!
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2459186
03/01/18 12:36 AM
03/01/18 12:36 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
that is beautiful, love the wheels and tires.
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2464633
03/11/18 10:44 AM
03/11/18 10:44 AM
300by500 Offline OP
300by500  Offline OP
Got the parts truck home last weekend, I've got both beds unbolted, unwired, and ready to swap today...
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2464885
03/11/18 07:50 PM
03/11/18 07:50 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
popcorn popcorn popcorn
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2465005
03/11/18 11:34 PM
03/11/18 11:34 PM
300by500 Offline OP
300by500  Offline OP
A cherry picker seemed to work really well to pick up the bed, but it could use a slightly longer arm insert to increase the reach. Another 6-8 inches would've made the job go a lot faster...
I was happy with how easy it was to move, it actually rolled around much easier than when loaded with an engine.
People who buy welders should be subjected to an I.Q. test!
This was a previous owner's attempt to fabricate a ball hitch mount in the bed.... tsk
That mess took about 2 hours to remove without damaging the frame, brake lines, wiring, fuel tank, etc. - but I was able to remove everything except some leftover steel plate welded along the length of one of the crossmembers.
When you use a 1/2 ton bed on a 3/4 or 1-ton you need to remove these little spacers for clearance, there are 2 on each side. The heavier trucks have a slightly taller frame in these areas. A Sawzall made pretty quick work of them...
Bed swap is complete! Next come the doors and fenders!
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2465037
03/12/18 12:35 AM
03/12/18 12:35 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
might as well do the cab and have a nice black truck!
Re: Scored a 12-valve... UPDATE! [Re: basketcase] #2465044
03/12/18 01:03 AM
03/12/18 01:03 AM
300by500 Offline OP
300by500  Offline OP
I'm considering doing that to match it up until it is all white, eventually. up
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2465088
03/12/18 08:13 AM
03/12/18 08:13 AM
Guitar Jones Offline
Looking good.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2468361
03/18/18 11:11 PM
03/18/18 11:11 PM
300by500 Offline OP
300by500  Offline OP
Doors done....
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2468747
03/19/18 08:18 PM
03/19/18 08:18 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Comin' together!
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2472098
03/26/18 01:16 AM
03/26/18 01:16 AM
300by500 Offline OP
300by500  Offline OP
Stripped the power windows/locks stuff from my old doors today, removed the last of the body parts from the parts truck, and loaded it up to haul it off to a guy who will part out the rest of it in exchange for a good left fender, a DODGE RAM stamped tailgate, and some other goodies.
Gotta love Southern Living where you can peel a 34 year-old fender from a vehicle and find it is completely rust-free.
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2472287
03/26/18 02:01 PM
03/26/18 02:01 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
very nice!
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2472321
03/26/18 03:10 PM
03/26/18 03:10 PM
That thing will be purty in no time.
Re: Scored a 12-valve... UPDATE! [Re: 300by500] #2475275
04/01/18 12:30 PM
04/01/18 12:30 PM
300by500 Offline OP
300by500  Offline OP
So I traded the leftovers for some other parts I needed - a nice gauge bezel, a DODGE RAM stamped tailgate and a left fender.
When I saw the fender I asked where it came from, and it turns out it came from a truck that had belonged to an old guy I not only had known- but I bought a '66 Fury from him over 10 years ago! I was able to find a pic of the truck sitting at his house on Google Earth. It was also at this spot where I first met fellow Moparts member "mattsmopars", when he brought a friend there to look at possibly buying the engine from the 66 before I parted it out.
Small world...
It'll be kind of neat to use a piece of his truck in his memory.
Page 2 of 3 1 2 3
