Filled block on the street #2464784
03/11/18 03:40 PM
03/11/18 03:40 PM
mld94
mld94
How would a 700hp low deck, 13-1, filled to 1 1/2" below the deck, electric pump, cool on the street ?
Would E85 make a big difference ?
Re: Filled block on the street [Re: ] #2464787
03/11/18 03:44 PM
03/11/18 03:44 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
You are going to need a good oil cooler, period.
Re: Filled block on the street [Re: ] #2464813
03/11/18 04:58 PM
03/11/18 04:58 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Depends on if you're driving a few miles to the drive-in or shopping center, or if you have a big fuel tank and want to go someplace 150 miles away.
Re: Filled block on the street [Re: ] #2464837
03/11/18 05:47 PM
03/11/18 05:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Water temps wont be the issue, oil temps will. I have a filled block street car with a big oil cooler and it has been that way since 2001 with zero ill affects. Hot days the oil temp will climb but with a good cooler its more than liveable
Re: Filled block on the street [Re: ] #2464881
03/11/18 07:42 PM
03/11/18 07:42 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I can't speak to the big block, but my 1/2 filled small block was totally fine... until I put the engine diaper on it... then things started getting HOT. Put a oil cooler on it... never a problem since.
Just plan on a cooler and you'll be fine.
Re: Filled block on the street [Re: dizuster] #2464890
03/11/18 08:00 PM
03/11/18 08:00 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
How far do most of the guys drive these 🚙. A quick trip for an icecreme cone or to a local cruise. If you drive further than that plan according
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Filled block on the street [Re: ] #2464908
03/11/18 08:39 PM
03/11/18 08:39 PM
mld94
mld94
10-15 miles....
Re: Filled block on the street [Re: dizuster] #2464909
03/11/18 08:40 PM
03/11/18 08:40 PM
mld94
mld94
Don't you run E85 ??
Re: Filled block on the street [Re: ] #2464912
03/11/18 08:42 PM
03/11/18 08:42 PM
K
KOS Offline
KOS  Offline
K
I ran a sb filled to the top ..tons of street driving ran good thick oil never had a prob.mind you never payed attention to oil temps just coolant which never ran hot.i think you'll be fine keep an eye on the oil just like a trans if it smells/looks burnt change it/ put a cooler on but I don't think you'll need to.
Re: Filled block on the street [Re: KOS] #2464927
03/11/18 09:07 PM
03/11/18 09:07 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I agree. Ran my 408 100 miles one way. No issues with oil too hot, but that depends on what is considered too hot. Block was filled just above soft plugs. Oil never got over 250* and i aways run 20/50 premium oil. I use Amsoil most of time with Brad Penn racing oil when moneys tight. No oil cooler on that one, but water temp was 200*-210* most of the time using electric pump and fan. Now have a 511 filled within 3" of the deck.Water temp was 185-195* most of the time past summer using mech pump and fan. Gonna try same without a cooler, but will be using Amsoil as 250* does not hurt it and Amsoil claims its good to 300*, will see.
Re: Filled block on the street [Re: ] #2464937
03/11/18 09:27 PM
03/11/18 09:27 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Ditto on comments. Only thing I noticed. When it did get "hot", it stayed hot and took some time to cool down, like many hours.
Re: Filled block on the street [Re: ] #2464993
03/11/18 11:21 PM
03/11/18 11:21 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I agree and that's what I run, an oil cooler.
Funny though we have 3 big blocks on the go, 2 strokers 1/2 fill and a 440 NO fill, the 440 is running the hottest on the water side and we are trying to sort this right now.
One way I was looking at it is if you have fill the oil down the bottom is not getting as much cooling from water and the water is not getting as much heat from the oil.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Filled block on the street [Re: ] #2465076
03/12/18 03:37 AM
03/12/18 03:37 AM
Earth
Rob C Offline
Rob C  Offline
Earth
E-85 will help the engine run cooler but as mentioned, oil!
Re: Filled block on the street [Re: Rob C] #2465277
03/12/18 04:36 PM
03/12/18 04:36 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My buddies Pontiac was half filled on his 10:70 street car that we sprayed also. It was fine temp wise & oil tempo wise under normal street driving. He drove it back & forth to work many times. In fact, it always ran cooler than any of my Mopars do (not filled).
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
