Filled block on the street
#2464784
03/11/18 03:40 PM
03/11/18 03:40 PM
mld94
mld94
How would a 700hp low deck, 13-1, filled to 1 1/2" below the deck, electric pump, cool on the street ?
Would E85 make a big difference ?
Re: Filled block on the street
[Re: ]
#2464813
03/11/18 04:58 PM
03/11/18 04:58 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Depends on if you're driving a few miles to the drive-in or shopping center, or if you have a big fuel tank and want to go someplace 150 miles away.
[Re: ]
#2464837
03/11/18 05:47 PM
03/11/18 05:47 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
Water temps wont be the issue, oil temps will. I have a filled block street car with a big oil cooler and it has been that way since 2001 with zero ill affects. Hot days the oil temp will climb but with a good cooler its more than liveable
[Re: dizuster]
#2464890
03/11/18 08:00 PM
03/11/18 08:00 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How far do most of the guys drive these 🚙. A quick trip for an icecreme cone or to a local cruise. If you drive further than that plan according
[Re: ]
#2464908
03/11/18 08:39 PM
03/11/18 08:39 PM
mld94
mld94
[Re: dizuster]
#2464909
03/11/18 08:40 PM
03/11/18 08:40 PM
mld94
mld94
I can't speak to the big block, but my 1/2 filled small block was totally fine... until I put the engine diaper on it... then things started getting HOT. Put a oil cooler on it... never a problem since.
Just plan on a cooler and you'll be fine. Don't you run E85 ??
[Re: ]
#2464993
03/11/18 11:21 PM
03/11/18 11:21 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I agree and that's what I run, an oil cooler.
Funny though we have 3 big blocks on the go, 2 strokers 1/2 fill and a 440 NO fill, the 440 is running the hottest on the water side and we are trying to sort this right now.
One way I was looking at it is if you have fill the oil down the bottom is not getting as much cooling from water and the water is not getting as much heat from the oil.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: Rob C]
#2465277
03/12/18 04:36 PM
03/12/18 04:36 PM
Posts: 4,540 Motor City
6PKRTSE
Motor City
My buddies Pontiac was half filled on his 10:70 street car that we sprayed also. It was fine temp wise & oil tempo wise under normal street driving. He drove it back & forth to work many times. In fact, it always ran cooler than any of my Mopars do (not filled).
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
