Leak proof valve cover gaskets #2464421
03/10/18 07:19 PM
03/10/18 07:19 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Having trouble with cork on stock cover. What do you guys use?
Re: Leak proof valve cover gaskets [Re: fastmark] #2464433
03/10/18 07:40 PM
03/10/18 07:40 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Have you tried Mr Gasket ultraseals?
Check with Superformance to see if they make a gasket suitable for stock covers.
Re: Leak proof valve cover gaskets [Re: fastmark] #2464452
03/10/18 08:21 PM
03/10/18 08:21 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Superformance Carbon-X Gasket. Best I've used. It sealed mine up; they're dry as a bone.
Re: Leak proof valve cover gaskets [Re: fastmark] #2464463
03/10/18 09:14 PM
03/10/18 09:14 PM
AndyF Offline
AndyF  Offline
40 year old stock valve covers can be damaged in so many ways you might never get them to seal. I don't know any surefire gaskets for stock valve covers. If you have a good cast cover with a nice flat machined surface then there are several different gaskets that will seal up nicely.
Re: Leak proof valve cover gaskets [Re: fastmark] #2464471
03/10/18 09:48 PM
03/10/18 09:48 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
What Andy says. Never had a problem with good cork gaskets, but I always spend time on stamped covers getting the rails dead straight & un-puckering the bolt holes. Cast covers are easier in that regard. The high-perf '68- '70 BB exhaust manifolds can bake calve cover gaskets, though, and the remedy I use for that is to replace them every few years before they start leaking.
Re: Leak proof valve cover gaskets [Re: topside] #2464510
03/10/18 11:51 PM
03/10/18 11:51 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I love my stock 340 valve covers but I have been fighting leaks for many years. I have used several different types of gaskets and sealants. I have also done the normal crack repair and straightening but those attempts did not stop all of the leaks. So I decided to add an aluminum spacer under the valve covers and two sets of the blue streak cork gaskets torqued to the stock 55in/lbs. So far the flat surface of the spacers seems to have helped the leaks even with cork gaskets.
Re: Leak proof valve cover gaskets [Re: fastmark] #2464548
03/11/18 01:41 AM
03/11/18 01:41 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I use spreaders on stamped valve covers to help keep the seal.
[image][/image]
Re: Leak proof valve cover gaskets [Re: fastmark] #2464586
03/11/18 03:46 AM
03/11/18 03:46 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Get some cast valve covers. If you must have the originals on iron heads, the best way is to smooth the rail on the head and glue the gasket to the cover using (sparingly) The Right Stuff. The cast rail on original heads is terrible. Narrow and filled with porosity. You have a 3/8 flange on the valve cover that tightens down to a 1/8"-3/16" rail. Over tightening can be a bad issue. The factory had those little boomerang and other pieces over the top of the valve cover rail for a reason.
Re: Leak proof valve cover gaskets [Re: Dave Hall] #2464630
03/11/18 10:16 AM
03/11/18 10:16 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
This is a restored, matching numbers, 440 4 speed Challenger. Can’t put cast covers on it.
Re: Leak proof valve cover gaskets [Re: fastmark] #2464697
03/11/18 01:05 PM
03/11/18 01:05 PM
sgcuda Offline
sgcuda  Offline
The best I ever used for stock covers was the Felpro performance gaskets. Black rubberized. They seemed to work best on the stock cast head surface, but in time, they will still leak.
[image][/image]
Re: Leak proof valve cover gaskets [Re: fastmark] #2464763
03/11/18 02:52 PM
03/11/18 02:52 PM
AndyF Offline
AndyF  Offline
Well now you have oil leaks just like the original cars did. That makes it a correct matching number car. It probably also leaks from the transmission and the differential just like the factory cars did.
Re: Leak proof valve cover gaskets [Re: fastmark] #2464766
03/11/18 03:03 PM
03/11/18 03:03 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I switched to cast valve covers years ago, use a crush proof gasket like Superformance. Never any leaks at all.
Re: Leak proof valve cover gaskets [Re: AndyF] #2464767
03/11/18 03:05 PM
03/11/18 03:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You are officially the biggest ass hat on Moparts........... blah
Re: Leak proof valve cover gaskets [Re: ProSport] #2464805
03/11/18 04:18 PM
03/11/18 04:18 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Me, too...
Using the old 'high-temp' VC gaskets...
Bone dry for a LONG time...
Unless I had a need for OEM correctness, I'd never go back to stamped...
Re: Leak proof valve cover gaskets [Re: fastmark] #2464845
03/11/18 06:14 PM
03/11/18 06:14 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Blue Moroso Perm-align gaskets. Rubber with steel inner skeleton. Best I've ever used, no leaks, reuseable. I'll never run anything else.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Leak proof valve cover gaskets [Re: fastmark] #2464892
03/11/18 08:05 PM
03/11/18 08:05 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I think the HP manifolds will burn them up no matter what you use. Are you running stock style exhaust on that Challenger?
Re: Leak proof valve cover gaskets [Re: A39Coronet] #2464893
03/11/18 08:10 PM
03/11/18 08:10 PM
K
KOS Offline
KOS  Offline
K
this or SCE but I'm not sure if they make em for factory style VCs I have them on my B1s and they are leak proof.
Re: Leak proof valve cover gaskets [Re: KOS] #2464931
03/11/18 09:12 PM
03/11/18 09:12 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I have the Realgasket brand on stock Hemi covers. They are molded from the red silicone with a fiberglass core. They seem to be doing the trick, if the directions are followed.
Re: Leak proof valve cover gaskets [Re: fastmark] #2464938
03/11/18 09:28 PM
03/11/18 09:28 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
I have the black sheet metal covers from Hughes. Gonna have the flanges machined flat as they are not straight and use the carbon x gaskets this year.
Re: Leak proof valve cover gaskets [Re: fastmark] #2464989
03/11/18 11:14 PM
03/11/18 11:14 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
One thing that caught me was I was using an old set of M/T covers on Indy heads, the underside of the cover where a bolt passes though was a different angle !! You think it tight but it isn't.
1963 Plymouth Max Wedge
1971 Barracuda
