Re: Leak proof valve cover gaskets
[Re: fastmark]
#2464433
03/10/18 07:40 PM
03/10/18 07:40 PM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
Have you tried Mr Gasket ultraseals? Check with Superformance to see if they make a gasket suitable for stock covers.
[Re: topside]
#2464510
03/10/18 11:51 PM
03/10/18 11:51 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
I love my stock 340 valve covers but I have been fighting leaks for many years. I have used several different types of gaskets and sealants. I have also done the normal crack repair and straightening but those attempts did not stop all of the leaks. So I decided to add an aluminum spacer under the valve covers and two sets of the blue streak cork gaskets torqued to the stock 55in/lbs. So far the flat surface of the spacers seems to have helped the leaks even with cork gaskets.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Dave Hall]
#2464630
03/11/18 10:16 AM
03/11/18 10:16 AM
Posts: 6,406 Abilene, Texas
fastmark
Abilene, Texas
Get some cast valve covers. If you must have the originals on iron heads, the best way is to smooth the rail on the head and glue the gasket to the cover using (sparingly) The Right Stuff. The cast rail on original heads is terrible. Narrow and filled with porosity. You have a 3/8 flange on the valve cover that tightens down to a 1/8"-3/16" rail. Over tightening can be a bad issue. The factory had those little boomerang and other pieces over the top of the valve cover rail for a reason. This is a restored, matching numbers, 440 4 speed Challenger. Can’t put cast covers on it.
[Re: fastmark]
#2464697
03/11/18 01:05 PM
03/11/18 01:05 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
The best I ever used for stock covers was the Felpro performance gaskets. Black rubberized. They seemed to work best on the stock cast head surface, but in time, they will still leak.
[image][/image]
[Re: fastmark]
#2464763
03/11/18 02:52 PM
03/11/18 02:52 PM
Posts: 31,041 Oregon
AndyF
Get some cast valve covers. If you must have the originals on iron heads, the best way is to smooth the rail on the head and glue the gasket to the cover using (sparingly) The Right Stuff. The cast rail on original heads is terrible. Narrow and filled with porosity. You have a 3/8 flange on the valve cover that tightens down to a 1/8"-3/16" rail. Over tightening can be a bad issue. The factory had those little boomerang and other pieces over the top of the valve cover rail for a reason. This is a restored, matching numbers, 440 4 speed Challenger. Can’t put cast covers on it. Well now you have oil leaks just like the original cars did. That makes it a correct matching number car. It probably also leaks from the transmission and the differential just like the factory cars did.
[Re: fastmark]
#2464766
03/11/18 03:03 PM
03/11/18 03:03 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I switched to cast valve covers years ago, use a crush proof gasket like Superformance. Never any leaks at all.
[Re: ProSport]
#2464805
03/11/18 04:18 PM
03/11/18 04:18 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I switched to cast valve covers years ago, use a crush proof gasket like Superformance. Never any leaks at all. Me, too... Using the old 'high-temp' VC gaskets... Bone dry for a LONG time... Unless I had a need for OEM correctness, I'd never go back to stamped...
[Re: A39Coronet]
#2464893
03/11/18 08:10 PM
03/11/18 08:10 PM
KOS
Blue Moroso Perm-align gaskets. Rubber with steel inner skeleton. Best I've ever used, no leaks, reuseable. I'll never run anything else. this or SCE but I'm not sure if they make em for factory style VCs I have them on my B1s and they are leak proof.
[Re: fastmark]
#2464989
03/11/18 11:14 PM
03/11/18 11:14 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
One thing that caught me was I was using an old set of M/T covers on Indy heads, the underside of the cover where a bolt passes though was a different angle !! You think it tight but it isn't.
1963 Plymouth Max Wedge 1971 Barracuda
