Page 1 of 2 1 2 >
#2461018 - 03/04/18 03:22 PM Cold air inlet
firefighter3931 Offline
Loc: Ontario,Canada
Thinking of using a Ram air box setup on my 68 Charger with the stock flat hood.
http://www.ramairbox.com/
These air cleaner assemblies are sealed and use 4inch hose. My question centers on the inlet location. I'm thinking of running the inlets into the inner fender where air would be drawn in around the front wheels.
Obviously there is no ram effect but I'm wondering if it would be worth the effort vs the current setup which is a standard 14x3 drop base assembly.
Opinions ? Comments ?
Ron
#2461032 - 03/04/18 04:08 PM Re: Cold air inlet [Re: firefighter3931]
Spaceman Spiff Online   penguin-006
Loc: jersey
how are you going to keep rocks, dirt, leaves, water, etc, out?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
#2461281 - 03/04/18 10:35 PM Re: Cold air inlet [Re: firefighter3931]
StealthWedge67 Offline
Loc: Puyallup, WA
I use a ramairbox setup. Mine pulls through some holes I cut in the core support. I thought about the same location you are thinking of. I tried to fab the hoses off those locations, just couldn’t do it. To tight and odd angles to deal with. Perhaps you’re better than I at fabrication. I think it could be a decent place to pull from except in the rain. Let us know how it works out. Here’s mine:
LemonWedge - Street heavy / Strip ready - 11.32 @ 117
#2461348 - 03/05/18 02:31 AM Re: Cold air inlet [Re: StealthWedge67]
Loc: Bend,OR USA
I like that, it looks good up bow
#2461355 - 03/05/18 06:00 AM Re: Cold air inlet [Re: firefighter3931]
Hemi ragtop Offline
Loc: Tennessee
Very clean and neat. I like the whole car! Any performance gains that you noticed after intall?
#2461857 - 03/05/18 11:33 PM Re: Cold air inlet [Re: Hemi ragtop]
Loc: Puyallup, WA
Thanks. I did it years ago when the original 383 was still in the car. If I remember correctly, I added it and changed carburetors at the same time, so it got faster but I can’t peg how much was this system vs the carb. Probably not much to be honest, but it certainly couldn’t have hurt it. It may be worth more to the current combo, since it is obviously drawing more air than the 383 did.
Regarding the ramairbox purchase, the product is very nicely finished and still looks great years later. Don’t hesitate to buy from them.
#2461968 - 03/06/18 09:57 AM Re: Cold air inlet [Re: firefighter3931]
The Shadow Offline
Loc: Duloc
Ron
If you can the cowl is a better area for air
Universal spinners is Scarborough makes the same type of housing
http://www.universalspinners.com/muscle-car-owners.php
#2462077 - 03/06/18 02:10 PM Re: Cold air inlet [Re: The Shadow]
Loc: Ontario,Canada
Thanks for the pics and feedback guys !
StealthWedge : that looks great....nice job on the install. Unfortunately in my case I don't have room to go through the core support. My aftermarket radiator has side tanks and is quite wide.
Shadow/Mark : I guess the cowl could work with a cowl scoop ?
I'm trying to keep the stock flat hood and don't like the look of any scoops on a 68-70 Charger hood.
My thinking was drawing ambiant air from the wheelwell area has to be much better than sucking 250* underhood air. My question really centered on how much better would it run and is it worth the expense ?
Ron
#2462359 - 03/06/18 09:17 PM Re: Cold air inlet [Re: firefighter3931]
csk Offline
Loc: KATY TEXAS
Ron
as far as 1/4 times I have no data, but after I sealed my air cleaner to my cowl hood the car ran much better on the street, the AFR was much more stable though the range of driving, the butt dyno says it had more power.
Edited by csk (03/06/18 09:18 PM)
LINK TO MY STORY http://www.onallcylinders.com/2015/11/16...-dodge-charger/
[url=https://flic.kr/p/Xdr9rm]
68 Charger daily driver 512 low deck, 4050lb,11.33 @ 121.1, 1750DA
in full street car trim.
#2462545 - 03/07/18 10:35 AM Re: Cold air inlet [Re: csk]
11secdart Offline
Loc: new jersey usa
Spectra makes a kit also I got mine from Summit. I put the set up in my D150 and also put one hole in the radiator support and connected one to the factory ducting which pulls air from under the turn signal. I put a piece of screen in front of the support inlet to keep out bugs, etc.
Edited by 11secdart (03/07/18 10:36 AM)
08 1500 Quad Cab Hemi 4x4
92 D150 5.2 (318) 2WD,shortbed,original owner, multiple time Trophy Class Winner @ Mopar Meets
68 Dart 408 ci, R3, Indy Heads, pump gas, 904, 3,150 lbs, footbrake, mid 11's
2013 Island Dragway Street Eliminator Points Champion
2014 Raceway Park ( R.I.P. 2018 ) 11.50 Index Points Champion
#2462565 - 03/07/18 11:11 AM Re: Cold air inlet [Re: firefighter3931]
dvw Online   content
Loc: MI, usa
Dizusters turbo car draws from the left inner wheel well. A K&N cone shaped filter is mounted in the wheel well behind the headlamp. One 4" tube/hose feeds 850hp. Street driven with no issue.
Doug
#2462687 - 03/07/18 02:36 PM Re: Cold air inlet [Re: firefighter3931]
Triggerfish Offline
Loc: Blairsden, CA
Ron, a friend of mine has a super nice (& fast) 65 Coronet 500 with the 17"x 5"setup on his RB 512 stroker with 2x4's. Ducted to the inner headlight buckets with mesh covering the openings. Looks really trick & flows good. I know you can't do that with your Charger's concealed head lights, but Spectra makes a firewall ducted unit that draws air from the vents at the base of the windshield. Similar to what Petty did on his 64 NASCAR Belvedere. I'm considering that with my 64 Belvedere. BTW, glad to see you still have your 68 Charger & would be great to get together with Holly's Charger again. Buzz
#2463355 - 03/08/18 06:44 PM Re: Cold air inlet [Re: firefighter3931]
The Shadow Offline
Loc: Duloc
Ron
you're in a bit of a quandary. Your machine is too nice to be cutting holes for air scoops in the inner fenders ,core support ,hell any place.
The cowl is a option for clean fresh air
#2463939 - 03/09/18 04:57 PM Re: Cold air inlet [Re: The Shadow]
mkdart Offline
Loc: northeast ohio
PM sent
#2464245 - 03/10/18 09:28 AM Re: Cold air inlet [Re: csk]
Loc: Ontario,Canada
Originally Posted By csk
As far as 1/4 times I have no data, but after I sealed my air cleaner to my cowl hood the car ran much better on the street, the AFR was much more stable though the range of driving, the butt dyno says it had more power.
Thanks Charlie.....that's what I figured. Stands to reason that a sealed carb to fresh air would show some improvement.
Ron
#2464247 - 03/10/18 09:34 AM Re: Cold air inlet [Re: Triggerfish]
Loc: Ontario,Canada
Hi Buzz,
Thanks for the info ! That cold air assembly looks effective but wouldn't work on a Charger. The wiper motor is right where that firewall ducting would have to be spliced in. It is still a street car and I need wipers apimp
Does Holly still have the '69....allways loved that car bow
Hope to make it back out to Vegas one of these years....allways a blast ! beer
Ron
#2464248 - 03/10/18 09:40 AM Re: Cold air inlet [Re: The Shadow]
Loc: Ontario,Canada
Originally Posted By The Shadow
Ron
Hey Mark,
Yep....it's too nice to cut up. I might have to rethink the aftermarket hood deal. A 'Glass hood sealed to the carb would be the least intrusive option (No Hacking)and provide some cool air with the ram effect. The added bonus would be a 50lb weight reduction on the nose. Just have to come up with something I like from an aesthetic standpoint. thumbs
Ron
#2464323 - 03/10/18 12:49 PM Re: Cold air inlet [Re: firefighter3931]
Triggerfish Offline
Loc: Blairsden, CA
Hi Buzz,
Ron
Ron, I bought a one piece fiberglass hood with a 6 Pack scoop for the 69 R/T SE I had & gave it to Holly for his 69. Its stuffed away in his shed & he'll never use it with his Hemi, so if you're interested, I'll ask him if he wants to part with it. Landy used the earlier Hemi scoop on his Charger, but the 6 pack may work better since it sits higher. Here's one on a 68 from google images.
#2464349 - 03/10/18 01:58 PM Re: Cold air inlet [Re: firefighter3931]
csk Offline
Loc: KATY TEXAS
The 2nd gen Charger is a difficult one for a hood scoop, the stock hood looks the best, for me the cowl hood looks better on a Charger than other scoops.
#2464389 - 03/10/18 03:18 PM Re: Cold air inlet [Re: firefighter3931]
Hemi ragtop Offline
Loc: Tennessee
Ron, your hood scoop is similar to mine. How do you like the ram air box I made for my 66'?
Page 1 of 2 1 2 >
25,485 Registered Members
192,957 Topics
1974 Plymouth Road Runner
by tomsjack
09/20/18 04:24 AM
wing car avon bottle $6.99
by EV2Bird
09/19/18 11:28 PM
72-74 factory Rear sway bar
by Fasbird
09/19/18 11:06 PM
1969 Plymouth Valiant 2DR
by FM3_1970
09/19/18 10:52 PM
