408" - looking for Input for possible install #2461474
03/05/18 02:25 PM
03/05/18 02:25 PM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
My car ('71 RR) was originally produced with a 383. I have had a 440-6 in it since 1979. I am getting ready to install the engine this spring, and considering the costs to go through the 440, can a 408" be purchased for a reasonable cost?
My questions are;
1. who has a 408" that can give me input about drivability/performance?
2. Is there a similar combo to put in?
And, any other feedback that anyone can offer.
Gar
Re: 408" - looking for Input for possible install [Re: Fasbird] #2461540
03/05/18 04:27 PM
03/05/18 04:27 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'm guessing you are asking about a 408" small block? For the cost to convert to a small block I'd just go through the 440. Even if you had the block and a good transmission the cost of the build will be more than the 440 rebuild.
Re: 408" - looking for Input for possible install [Re: justinp61] #2461606
03/05/18 06:25 PM
03/05/18 06:25 PM
Keymar, MD
DusterKid Online content
DusterKid  Online Content
Keymar, MD
100% agreed.
Re: 408" - looking for Input for possible install [Re: DusterKid] #2461620
03/05/18 07:02 PM
03/05/18 07:02 PM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
Yeah, I suppose you are both right. I have all the stuff to put the 440 together. probably getting too old to just go out and get it done....lol.
Re: 408" - looking for Input for possible install [Re: Fasbird] #2461652
03/05/18 08:30 PM
03/05/18 08:30 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
Yep, if it were mine I would just stay with the 440. Too much
involved to swap everything to small block status. Engine/trans/radiator/driveshaft..blah blah.. blah
Plymouth Makes It!
Re: 408" - looking for Input for possible install [Re: Fasbird] #2461663
03/05/18 09:05 PM
03/05/18 09:05 PM
crlush Offline
crlush  Offline
I wouldn't put a small block in place of your 440.
Re: 408" - looking for Input for possible install [Re: Fasbird] #2461785
03/06/18 12:35 AM
03/06/18 12:35 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
As a 408 stroker owner I would suggest sticking with the 440 for cost and results. 408s are cool if you are replacing a small block but there is no replacement for displacement. Stick with the bigblock.
Re: 408" - looking for Input for possible install [Re: stumpy] #2461793
03/06/18 12:41 AM
03/06/18 12:41 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I have fun out running big blocks with my small blocks.
Re: 408" - looking for Input for possible install [Re: Fasbird] #2461803
03/06/18 12:54 AM
03/06/18 12:54 AM
Grand Prairie,Texas
Grand Prairie,Texas
I'll bet you have a lot more invested in your small blocks to do it.
Re: 408" - looking for Input for possible install [Re: stumpy] #2461861
03/06/18 02:40 AM
03/06/18 02:40 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Be very careful with your money, Dan's cars run very hard. With iron heads I might add.
