Re: 408" - looking for Input for possible install
[Re: justinp61]
#2461606
03/05/18 06:25 PM
03/05/18 06:25 PM
Posts: 1,776 Keymar, MD
DusterKid
Keymar, MD
I'm guessing you are asking about a 408" small block? For the cost to convert to a small block I'd just go through the 440. Even if you had the block and a good transmission the cost of the build will be more than the 440 rebuild. 100% agreed.
[Re: Fasbird]
#2461652
03/05/18 08:30 PM
03/05/18 08:30 PM
Posts: 5,345 Planet Earth
RoadRunnerLuva
Planet Earth
Yep, if it were mine I would just stay with the 440. Too much involved to swap everything to small block status. Engine/trans/radiator/driveshaft..blah blah..
Plymouth Makes It!
[Re: stumpy]
#2461861
03/06/18 02:40 AM
03/06/18 02:40 AM
Posts: 11,685 W. Kentucky
justinp61
W. Kentucky
I'll bet you have a lot more invested in your small blocks to do it. Be very careful with your money, Dan's cars run very hard. With iron heads I might add.
