318 2 bbl to 4 bbl swap Question #246073
03/07/09 07:36 PM
03/07/09 07:36 PM
ILLINOIS
V
volaredon Offline OP
V
ILLINOIS
I just swapped from a 2 bbl (small Holley, BBD equivalent) to a Performer and AFB combo in my truck.
I want to be able to still use the Cruise. Is the Cruise Control cable different for a 2 BBL, vs. a 4 BBL? it appears that the cable sticks out farther from the housing on the 4 BBL one. (but I didnt have my truck next to the van when I pulled the carb to be sure) Can anyone out there say for sure?
Re: 318 2 bbl to 4 bbl swap Question [Re: volaredon] #246074
03/07/09 09:33 PM
03/07/09 09:33 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
not much help,,, but I know that the main throttle shafts are different in vans and trucks. the vans hookup about 1/2" further forward than the trucks..
I am truckless..
Re: 318 2 bbl to 4 bbl swap Question [Re: volaredon] #246075
03/07/09 10:31 PM
03/07/09 10:31 PM
Joplin, MO
734x4PW Offline
734x4PW  Offline
Joplin, MO
Just customize. Attach the cable so it has just a tad bit of slack at base idle adjustment and you're good to go.
Mark
Re: 318 2 bbl to 4 bbl swap Question [Re: volaredon] #246076
03/07/09 10:45 PM
03/07/09 10:45 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Are you using a 4-bbl bracket?
Re: 318 2 bbl to 4 bbl swap Question [Re: In_The_Pink] #246077
03/07/09 11:26 PM
03/07/09 11:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
When I converted my 87 Diplomat to 4bbl I had to swap teh lever from the old 2bbl to the linkage adapter Ebrock sells. This bracket it what teh cable hooks to on the carb itself. Other than that it was a simple swap as far as cruise goes, but I did use the 4bbl linkages and such, not the 2bbl ones.
Don't be the exception.
Re: 318 2 bbl to 4 bbl swap Question [Re: Supercuda] #246078
03/08/09 11:07 PM
03/08/09 11:07 PM
Sarasota FL.
surfman Offline
surfman  Offline
Sarasota FL.
When you convert to a 4 bbl carb the carb lever is further forward than the 2 bbl. Chrysler used a completely different cable bracket, cable, and if cruise control is used the bracket that holds the cruise cable is different too. The downshift rods and throttle cable are different-longer. If you don't have the factory parts you will need to change or rework a lot of things for it to operate properly.
Re: 318 2 bbl to 4 bbl swap Question [Re: surfman] #246079
03/10/09 02:31 AM
03/10/09 02:31 AM
ILLINOIS
V
V
ILLINOIS
I have the 4 bbl bracket AND the Eddy Mopar carb adaptor bracket. I have modded the KD linkage to work but the cruise cable for a 4 BBL seems like it oughtta have more cable sticking out past the housing the way the CC cable attatches to the 4 BBL bracket (the "hold down" is behind (closer to firewall) on the 4 BBL setup than for the 2 BBL version. I'm going back to that yard tomorrow anyway so I guess I'll get the CC cable from that van to be sure. (Hopefully a van one will be long enough for a pick up)
