2012 Dodge Ram 2500 4X4 diesel pickup mirror question???
#2460225
03/02/18 11:14 PM
03/02/18 11:14 PM
Posts: 609 Sometimes Northern California,...
LO23M8B
Does anyone have any idea if there is a fuse for the side mirrors that controls the mirror turn signals and puddle lights. Also, the center cab stop light? Are they part of the same circuit? I can't figure out why both mirror turn signals and puddle lights don't work??? If there is a fuse, what number is it. And also is the middle stop light on top of the cab part of it. They all went south at the same time so Im thinking a fuse???? Whats funny is the a mirror adjustments work fine on both sides. What gives???? UGH
64 S/S Hemi Plymouth, 1963 4-Door (13.5-1) Max Wedge Savoy, 69-440 Dart 10.20 et 132 mph on the footbrake, 2012 Dodge Ram 2500 turbo diesel, 69-440-6 Roadrunner, 05 Hemi Magnum, 2003 Dodge Ram 2500 P/u, 2005 Viper, 98' Town & Country.
Re: Dodge Ram 2500 4X4 diesel pickup mirror question???
[Re: LO23M8B]
#2460369
03/03/18 09:06 AM
03/03/18 09:06 AM
Guitar Jones
[Re: LO23M8B]
#2460490
03/03/18 02:29 PM
03/03/18 02:29 PM
LO23M8B
2012 is the year. I'll download the owners app off the net. Thanks for the help.
[Re: LO23M8B]
#2460842
03/04/18 12:58 PM
03/04/18 12:58 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
I have a 2011 2500. The left puddle light stopped working a couple of years ago. The right side has a mind of it's own. After checking on the cost of replacements, i'm not going to worry with them.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: 2012 Dodge Ram 2500 4X4 diesel pickup mirror question???
[Re: LO23M8B]
#2461053
03/04/18 07:35 PM
03/04/18 07:35 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Start with a test light and see if you have power going to the socket.An electrical spike can take out a bulb at under 15 volts.Ny 2500 is a little older but diagnostics are the same.
[Re: LO23M8B]
#2461627
03/05/18 07:18 PM
03/05/18 07:18 PM
LO23M8B
UPDATE: As it turns out, it is the lights. I guess I hadn't really noticed them being out for a bit. 1 puddle light works, used it to check the other and bingo, bad light. Problem is they come in pairs and you have to buy 2. Mirror lights out as well. I try to pull my mirrors in whenever I park the truck but sometimes you forget. They've been smacked a bunch so maybe that is what caused the turn signal mirror lights to go out. Anyway, looks like all is good. Thanks for the help!
