2012 Dodge Ram 2500 4X4 diesel pickup mirror question???
#2460225
03/02/18 11:14 PM
03/02/18 11:14 PM
Posts: 609 Sometimes Northern California,...
LO23M8B
Does anyone have any idea if there is a fuse for the side mirrors that controls the mirror turn signals and puddle lights. Also, the center cab stop light? Are they part of the same circuit? I can't figure out why both mirror turn signals and puddle lights don't work??? If there is a fuse, what number is it. And also is the middle stop light on top of the cab part of it. They all went south at the same time so Im thinking a fuse???? Whats funny is the a mirror adjustments work fine on both sides. What gives???? UGH
64 S/S Hemi Plymouth, 1963 4-Door (13.5-1) Max Wedge Savoy, 69-440 Dart 10.20 et 132 mph on the footbrake, 2012 Dodge Ram 2500 turbo diesel, 69-440-6 Roadrunner, 05 Hemi Magnum, 2003 Dodge Ram 2500 P/u, 2005 Viper, 98' Town & Country.
Re: Dodge Ram 2500 4X4 diesel pickup mirror question???
[Re: LO23M8B]
#2460369
03/03/18 09:06 AM
03/03/18 09:06 AM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: LO23M8B]
#2460490
03/03/18 02:29 PM
03/03/18 02:29 PM
LO23M8B
2012 is the year. I'll download the owners app off the net. Thanks for the help.
[Re: LO23M8B]
#2460842
03/04/18 12:58 PM
03/04/18 12:58 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
I have a 2011 2500. The left puddle light stopped working a couple of years ago. The right side has a mind of it's own. After checking on the cost of replacements, i'm not going to worry with them.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: 2012 Dodge Ram 2500 4X4 diesel pickup mirror question???
[Re: LO23M8B]
#2461053
03/04/18 07:35 PM
03/04/18 07:35 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Start with a test light and see if you have power going to the socket.An electrical spike can take out a bulb at under 15 volts.Ny 2500 is a little older but diagnostics are the same.
[Re: LO23M8B]
#2461627
03/05/18 07:18 PM
03/05/18 07:18 PM
LO23M8B
UPDATE: As it turns out, it is the lights. I guess I hadn't really noticed them being out for a bit. 1 puddle light works, used it to check the other and bingo, bad light. Problem is they come in pairs and you have to buy 2. Mirror lights out as well. I try to pull my mirrors in whenever I park the truck but sometimes you forget. They've been smacked a bunch so maybe that is what caused the turn signal mirror lights to go out. Anyway, looks like all is good. Thanks for the help!
