2012 Dodge Ram 2500 4X4 diesel pickup mirror question??? #2460225
03/02/18 11:14 PM
03/02/18 11:14 PM
Sometimes Northern California,...
LO23M8B Offline OP
LO23M8B  Offline OP
Does anyone have any idea if there is a fuse for the side mirrors that controls the mirror turn signals and puddle lights. Also, the center cab stop light? Are they part of the same circuit? I can't figure out why both mirror turn signals and puddle lights don't work??? If there is a fuse, what number is it. And also is the middle stop light on top of the cab part of it. They all went south at the same time so Im thinking a fuse???? Whats funny is the a mirror adjustments work fine on both sides. What gives???? UGH
64 S/S Hemi Plymouth, 1963 4-Door (13.5-1) Max Wedge Savoy, 69-440 Dart 10.20 et 132 mph on the footbrake, 2012 Dodge Ram 2500 turbo diesel, 69-440-6 Roadrunner, 05 Hemi Magnum, 2003 Dodge Ram 2500 P/u, 2005 Viper, 98' Town & Country.
Re: Dodge Ram 2500 4X4 diesel pickup mirror question??? [Re: LO23M8B] #2460246
03/02/18 11:56 PM
03/02/18 11:56 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
No owners manual?
Angry white pureblood male
Re: Dodge Ram 2500 4X4 diesel pickup mirror question??? [Re: LO23M8B] #2460369
03/03/18 09:06 AM
03/03/18 09:06 AM
Guitar Jones Offline
Not even a model year?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Dodge Ram 2500 4X4 diesel pickup mirror question??? [Re: LO23M8B] #2460490
03/03/18 02:29 PM
03/03/18 02:29 PM
LO23M8B Offline OP
LO23M8B  Offline OP
2012 is the year. I'll download the owners app off the net.
Thanks for the help.
Re: Dodge Ram 2500 4X4 diesel pickup mirror question??? [Re: LO23M8B] #2460620
03/03/18 09:32 PM
03/03/18 09:32 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
check the ram forum . . . good info there
Re: Dodge Ram 2500 4X4 diesel pickup mirror question??? [Re: LO23M8B] #2460636
03/03/18 10:34 PM
03/03/18 10:34 PM
Chicago
curbman68 Offline
curbman68  Offline
Chicago
The mirror lights don't seem to be very durable, I have a 2010 and when I bought it all mirror lights were out. Replaced all of them and one puddle light lasted less than a year. They are a little pricey for what they are but not terrible. Not sure I'll keep replacing them if the replacements don't last
Re: Dodge Ram 2500 4X4 diesel pickup mirror question??? [Re: LO23M8B] #2460842
03/04/18 12:58 PM
03/04/18 12:58 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I have a 2011 2500. The left puddle light stopped working a couple of years ago. The right side has a mind of it's own. After checking on the cost of replacements, i'm not going to worry with them.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: 2012 Dodge Ram 2500 4X4 diesel pickup mirror question??? [Re: LO23M8B] #2461053
03/04/18 07:35 PM
03/04/18 07:35 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Start with a test light and see if you have power going to the socket.An electrical spike can take out a bulb at under 15 volts.Ny 2500 is a little older but diagnostics are the same.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 2012 Dodge Ram 2500 4X4 diesel pickup mirror question??? [Re: LO23M8B] #2461627
03/05/18 07:18 PM
03/05/18 07:18 PM
LO23M8B Offline OP
LO23M8B  Offline OP
UPDATE: As it turns out, it is the lights. I guess I hadn't really noticed them being out for a bit. 1 puddle light works, used it to check the other and bingo, bad light. Problem is they come in pairs and you have to buy 2. Mirror lights out as well. I try to pull my mirrors in whenever I park the truck but sometimes you forget. They've been smacked a bunch so maybe that is what caused the turn signal mirror lights to go out. Anyway, looks like all is good. Thanks for the help!
