MP cast aluminun valve covers/PCV valve #2460000
03/02/18 05:22 PM
03/02/18 05:22 PM
Penna
70satelliteguy Offline OP
Penna
Anyone have an easy way of making a PCV valve work with the MP aluminum
Black wrinkle valve covers? Openings are really only intended to fit a breather.
Mike
Re: MP cast aluminun valve covers/PCV valve [Re: 70satelliteguy] #2460011
03/02/18 05:52 PM
03/02/18 05:52 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Mike
It's easy. Drill them out to size (don't try to "punch" them out like some guys do) and use one of the special grommets. The grommets for the stamped covers don't work--the ones specifically designed for the aluminum covers are a little thicker. PCV on drivers side, breather on the passenger.
https://www.ebay.com/i/273078104097?chn=ps (don't pay $50--you can find them for way less)
Oh, and make sure you have the little baffle installed that comes with the covers or the PCV will suck oil.
Looks like this:
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: MP cast aluminun valve covers/PCV valve [Re: 70satelliteguy] #2460026
03/02/18 06:30 PM
03/02/18 06:30 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Re: MP cast aluminun valve covers/PCV valve [Re: DusterKid] #2460572
03/03/18 06:40 PM
03/03/18 06:40 PM
Penna
Penna
Thank You for the reply's
Mike
Re: MP cast aluminun valve covers/PCV valve [Re: 70satelliteguy] #2460646
03/03/18 10:59 PM
03/03/18 10:59 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I found a Spectre push-in oil filler cap at the local AutoZone that has a PCV built into it. I used that on my Indy covers instead of the push-in open-element breather that the car came with (had no PCV valve).
Re: MP cast aluminun valve covers/PCV valve [Re: wingman] #2460883
03/04/18 02:04 PM
03/04/18 02:04 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I used a hole saw from Lowes, and then moved the baffle to that spot. Be sure to use locktite on the small mounting screws. Summit sells the MP grommets that fit them.
I also spray painted the covers Hemi Orange and sanded the fins to get the paint off them to accent the covers again. They look nice that way.
