Anyone have an easy way of making a PCV valve work with the MP aluminum
Black wrinkle valve covers? Openings are really only intended to fit a breather.
Mike
It's easy. Drill them out to size (don't try to "punch" them out like some guys do) and use one of the special grommets. The grommets for the stamped covers don't work--the ones specifically designed for the aluminum covers are a little thicker. PCV on drivers side, breather on the passenger.
https://www.ebay.com/i/273078104097?chn=ps (don't pay $50--you can find them for way less)
Oh, and make sure you have the little baffle installed that comes with the covers or the PCV will suck oil.
Looks like this:
