Re: flex plate
[Re: DoubleD]
#2459955
03/02/18 04:07 PM
03/02/18 04:07 PM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
I found this ATI high HP solution - but I would guess the converter has to be made for it- a dual bolt pattern - our new converteres came with this this dual pattern lug on them allowing for 8 bolts - but we are using the B&M hence the converter has one hole tapped to 7/16 at each lug while the other is 1/2"
Re: flex plate
[Re: RustyM]
#2463065
03/08/18 01:22 PM
03/08/18 01:22 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
