flex plate #2459853
03/02/18 11:48 AM
03/02/18 11:48 AM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
511/727- steel crank/6 bolt.
what sfi flex plate for bracket car.
I see the large round ones but know nothing whatsoever about them.
9 inch converter
any recommendations?
Re: flex plate [Re: RustyM] #2459868
03/02/18 12:32 PM
03/02/18 12:32 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
B&M will be fine.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: flex plate [Re: RustyM] #2459921
03/02/18 02:27 PM
03/02/18 02:27 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run the B&M as well. Aprox 900 hp, no issue.
Doug
Re: flex plate [Re: RustyM] #2459928
03/02/18 02:58 PM
03/02/18 02:58 PM
I use the Mopar brand for SFI, they only offer the one with the H.D. 11 inch bolt pattern with the larger 7/16 inch converter bolts in both 6 bolt 440 and 8 bolt hemi patterns scope up
I've heard to many complaints on the B&M plates not fitting all converters correctly for me to try one down
Maybe it was the converters, maybe not confused shruggy I've never heard anyone complain on the Mopar H.D. not fitting Mopar race converters of any brand work
Re: flex plate [Re: RustyM] #2459952
03/02/18 03:57 PM
03/02/18 03:57 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The Mopar ones as of late seem to crack after awhile - We had one crack and switched to the B&M - and yes you have to bench fit them first as they are on the tight side when bolting to the converter - I think the real issue is converter mounting lugs can vary just enough to make the difference - on both of the B&M's we use - we had to reem the converter holes a little - no problen since
Re: flex plate [Re: DoubleD] #2459955
03/02/18 04:07 PM
03/02/18 04:07 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I found this ATI high HP solution - but I would guess the converter has to be made for it- a dual bolt pattern - our new converteres came with this this dual pattern lug on them allowing for 8 bolts - but we are using the B&M hence the converter has one hole tapped to 7/16 at each lug while the other is 1/2"
Re: flex plate [Re: RustyM] #2463065
03/08/18 01:22 PM
03/08/18 01:22 PM
an8sec70cuda Offline
B&M on my stuff.
CHIP
'06 GMC 2500HD LBZ Duramax
