#2459853 - 03/02/18 08:48 AM flex plate
RustyM Online   content
Loc: Texas
511/727- steel crank/6 bolt.
what sfi flex plate for bracket car.
I see the large round ones but know nothing whatsoever about them.
9 inch converter
any recommendations?
#2459868 - 03/02/18 09:32 AM Re: flex plate [Re: RustyM]
hemi-itis Offline
Loc: Great Neck,LI,new york
B&M will be fine.
HEMI-ITIS has no cure. My condition is fully BLOWN!!!
New beat 60 1.42,1/8 6.0 @117 9.38 @146.75.6 lbs boost @3700 lbs
#2459921 - 03/02/18 11:27 AM Re: flex plate [Re: RustyM]
dvw Online   content
Loc: MI, usa
I run the B&M as well. Aprox 900 hp, no issue.
#2459928 - 03/02/18 11:58 AM Re: flex plate [Re: RustyM]
Loc: Bend,OR USA
I use the Mopar brand for SFI, they only offer the one with the H.D. 11 inch bolt pattern with the larger 7/16 inch converter bolts in both 6 bolt 440 and 8 bolt hemi patterns scope up
I've heard to many complaints on the B&M plates not fitting all converters correctly for me to try one down
Maybe it was the converters, maybe not confused shruggy I've never heard anyone complain on the Mopar H.D. not fitting Mopar race converters of any brand work
#2459952 - 03/02/18 12:57 PM Re: flex plate [Re: RustyM]
DoubleD Offline
Loc: NE Ohio
The Mopar ones as of late seem to crack after awhile - We had one crack and switched to the B&M - and yes you have to bench fit them first as they are on the tight side when bolting to the converter - I think the real issue is converter mounting lugs can vary just enough to make the difference - on both of the B&M's we use - we had to reem the converter holes a little - no problen since
#2459955 - 03/02/18 01:07 PM Re: flex plate [Re: DoubleD]
DoubleD Offline
Loc: NE Ohio
I found this ATI high HP solution - but I would guess the converter has to be made for it- a dual bolt pattern - our new converteres came with this this dual pattern lug on them allowing for 8 bolts - but we are using the B&M hence the converter has one hole tapped to 7/16 at each lug while the other is 1/2"
Edited by DoubleD (03/02/18 01:48 PM)
#2463065 - 03/08/18 10:22 AM Re: flex plate [Re: RustyM]
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
B&M on my stuff.
'70 hemicuda...8.91 at 150.5 mph street car...Mopar Action feature Dec. '14
'69 road runner 446" w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'01 Ram 2500 QCSB 4x4 Cummins...toy hauler
'16 Grand Caravan hauler
25,196 Registered Members
187,587 Topics
1966 Coronet 440 Convertible - how rare is it ?
by Trulyvintage
03/17/18 11:27 AM
Pinion contact thoughts.
by Scamp408
03/17/18 11:24 AM
All Access Subscribers
by Leigh
03/17/18 10:38 AM
$14,998 gets the Hellcat crate now
by DaveRS23
03/17/18 10:02 AM
