Mini Starter #2459605
03/01/18 09:43 PM
03/01/18 09:43 PM
N.C.
W
wupracing Offline OP
W
N.C.
What starter are you using with the JW bell housing on a Big Block.
Re: Mini Starter [Re: wupracing] #2459613
03/01/18 09:58 PM
03/01/18 09:58 PM
Mi USA
Dyno Donnie Offline
Dyno Donnie  Offline
Mi USA
Powermaster 9533 here but i have ATI superbell. Dont know about JW.
Re: Mini Starter [Re: Dyno Donnie] #2459708
03/02/18 12:46 AM
03/02/18 12:46 AM
okla.
sam64 Offline
sam64  Offline
okla.
97 ram 1500 5.9 with the wire adapter reomoved.J&W bell on powerglide behind 440.
Re: Mini Starter [Re: wupracing] #2459788
03/02/18 05:32 AM
03/02/18 05:32 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Autozone 17010. Tell them you have an 88 fifth ave. with a 318. About $75 with a lifetime warranty.
Re: Mini Starter [Re: qwkmopardan] #2459816
03/02/18 10:04 AM
03/02/18 10:04 AM
N.C.
W
W
N.C.
The Autozone 17010 Are you running this starter behind the JW bell housing if so did you use any shims.
Re: Mini Starter [Re: sam64] #2459880
03/02/18 01:05 PM
03/02/18 01:05 PM
okla.
sam64 Offline
sam64  Offline
okla.
I have 2 of the shims that came with the bell on mine.
Re: Mini Starter [Re: sam64] #2460229
03/02/18 11:19 PM
03/02/18 11:19 PM
N.C.
W
W
N.C.
First off let me say I have a Powerglide with the JW Bell housing on it.I had a starter in the shop off a 99 Dakota that had the 5.2 engine in it and with 4 shims the teeth on the starter is still touching the flywheel.Wanted to see what other people are running before I went I bought one..
Re: Mini Starter [Re: wupracing] #2460318
03/03/18 02:20 AM
03/03/18 02:20 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I made a plate the thickness of the shim I needed to bolt the starter up to the bell. It looks like the mounting face of the starter. JW makes an extension for the nose or you could have them both made.
Re: Mini Starter [Re: Dave Hall] #2460319
03/03/18 02:22 AM
03/03/18 02:22 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
[quote=Dave Hall]I made a plate the thickness of the shim I needed to bolt the starter up to the bell. It looks like the mounting face of the starter. JW makes an extension for the nose or you could have them both made. [/quote
Summit sells a shim and nose piece kit. ]
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Mini Starter [Re: wupracing] #2460328
03/03/18 02:34 AM
03/03/18 02:34 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
FWIW, my shim ended up being .77 thick. I think it had more to do with the Meziere wheel than anything else...
