#2459605 - 03/01/18 06:43 PM Mini Starter
wupracing Offline
Loc: N.C.
What starter are you using with the JW bell housing on a Big Block.
#2459613 - 03/01/18 06:58 PM Re: Mini Starter [Re: wupracing]
Dyno Donnie Offline
Loc: Mi USA
Powermaster 9533 here but i have ATI superbell. Dont know about JW.
#2459708 - 03/01/18 09:46 PM Re: Mini Starter [Re: Dyno Donnie]
sam64 Offline
Loc: okla.
97 ram 1500 5.9 with the wire adapter reomoved.J&W bell on powerglide behind 440.
10.86@123
#2459788 - 03/02/18 02:32 AM Re: Mini Starter [Re: wupracing]
qwkmopardan Offline
Loc: Affton MO
Autozone 17010. Tell them you have an 88 fifth ave. with a 318. About $75 with a lifetime warranty.
#2459816 - 03/02/18 07:04 AM Re: Mini Starter [Re: qwkmopardan]
wupracing Offline
Loc: N.C.
The Autozone 17010 Are you running this starter behind the JW bell housing if so did you use any shims.
Edited by wupracing (03/02/18 07:05 AM)
#2459880 - 03/02/18 10:05 AM Re: Mini Starter [Re: sam64]
sam64 Offline
Loc: okla.
I have 2 of the shims that came with the bell on mine.
10.86@123
#2460229 - 03/02/18 08:19 PM Re: Mini Starter [Re: sam64]
wupracing Offline
Loc: N.C.
First off let me say I have a Powerglide with the JW Bell housing on it.I had a starter in the shop off a 99 Dakota that had the 5.2 engine in it and with 4 shims the teeth on the starter is still touching the flywheel.Wanted to see what other people are running before I went I bought one..
#2460318 - 03/02/18 11:20 PM Re: Mini Starter [Re: wupracing]
Dave Hall Offline
Loc: Cotati, CA
I made a plate the thickness of the shim I needed to bolt the starter up to the bell. It looks like the mounting face of the starter. JW makes an extension for the nose or you could have them both made.
#2460319 - 03/02/18 11:22 PM Re: Mini Starter [Re: Dave Hall]
pittsburghracer Online   work
Slowride
Loc: PA.
[quote=Dave Hall]I made a plate the thickness of the shim I needed to bolt the starter up to the bell. It looks like the mounting face of the starter. JW makes an extension for the nose or you could have them both made. [/quote
Summit sells a shim and nose piece kit. ]
1970 Duster
Edelbrock headed 408
6.143@110.89 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
6.001@113.27mph
9.44@138.23
Untitled by John Cadamore, on Flickr
#2460328 - 03/02/18 11:34 PM Re: Mini Starter [Re: wupracing]
Dave Hall Offline
Loc: Cotati, CA
FWIW, my shim ended up being .77 thick. I think it had more to do with the Meziere wheel than anything else...
25,341 Registered Members
190,152 Topics
Most users ever online: 1,417 @ 06/18/18 08:39 PM
Cuda and Challenger glass alike
by gregok
06/19/18 03:33 PM
new 440 source heads
by Moparnut426
06/19/18 03:23 PM
FM3 318 Chally project on eBay
by jeff968
06/19/18 02:51 PM
Plastic dash vents: Dye or paint?
by 1970RT
06/19/18 02:03 PM
