Repro door glass #2458671
02/28/18 01:07 AM
02/28/18 01:07 AM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
Any one have issues with the AMD door glass? 1972 Duster. Previous owner had shop install and windows did not shut right, too much gap at the front. I somehow managed to get the drivers to align really well. I've been fighting the passenger side for two nights now. I think I've got it as good as can be but the glass seems not wide enough. I have it toward the front of the car as close where it barely hits the weathers stripping, but the rear barely hit the wether stripping towards the back. Seems window is not exactly the right size. I also noticed the holes for the up stops, are too far up not allowing the window to go up and seal if I put the stops in. there is very limited wear and no broken slide squares/rollers, this is a 28k original mileage car. Just wondering if there were issue with some of the AMD product in the past.
Re: Repro door glass [Re: kbcuda] #2458781
02/28/18 12:13 PM
02/28/18 12:13 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have heard it depends on the car. Some fit really well & others not so much? I guess the same goes for some of their sheet metal also. But at least it gives us all a great starting point. None of us would be saving these cars if it wasn't for companies like AMD and many others trying their best to recreate these parts.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Repro door glass [Re: 6PKRTSE] #2458788
02/28/18 12:30 PM
02/28/18 12:30 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I put a drivers window in my 71 Charger and fit was perfect, I also compared them before the install though.
Ron
Re: Repro door glass [Re: kbcuda] #2458874
02/28/18 02:18 PM
02/28/18 02:18 PM
Canada
demon Offline
demon  Offline
Canada
Can't speak for your situation,and if you don't have an original glass to compare to, who knows. But that said, I have installed lots of AMD glass with no issues.
There are a ton of adjustments on door glass. Make sure you are familiar with all the adjustments. One piece glass like a Duster, being wedge shaped, can appear too short if it isn't up enough.
Re: Repro door glass [Re: kbcuda] #2458922
02/28/18 03:30 PM
02/28/18 03:30 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
It seems to be maxed out, and that's with the stop pegs removed.
