Re: Hemi Shuts off
[Re: dynorad]
#2458887
02/28/18 02:37 PM
02/28/18 02:37 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
I was having a intermediate shut off issue in my Charger with a 440 Sixpack it turned out to be the bulk head connection at the firewall. Maybe unplug your engine harness, clean all of the connections, make sure that all of the terminals are poking out thru the connectors properly & lube with dielectric grease.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: Hemi Shuts off
[Re: Jimmy H]
#2458915
02/28/18 03:20 PM
02/28/18 03:20 PM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
once you get in your 70's you forget stuff. I recall always having one in my cars. Can you test one to see if it works? Also thanks for your help Test one what? Ballast resister? Yup, use an ohm meter. Also can be a multimeter. Unplug the connector on one end of the resister on the car, and test it.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Hemi Shuts off
[Re: Jimmy H]
#2459008
02/28/18 06:44 PM
02/28/18 06:44 PM
Posts: 512 Niwot, CO Formerly denn...
dynorad
The other test you can do is to jumper across it and see if the engine runs. You don't want to let it continue running that way as you could overheat the coil. It won't run with he ballast unplugged.
