Hemi Shuts off #2458866
02/28/18 02:13 PM
02/28/18 02:13 PM
usa
Jimmy H Offline OP
Jimmy H  Offline OP
usa
Hello my mopar friends. I have not posted in quite a while. No longer have gtx or roadrunn, but still have 1971 Cuda. My question is: engine starts but stops quickly. It is a 1971 hemi engine. changed coil already. Trying to get it back on the road.
suggestions please ...Jim
Re: Hemi Shuts off [Re: Jimmy H] #2458870
02/28/18 02:17 PM
02/28/18 02:17 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
Ballast resistor?
Re: Hemi Shuts off [Re: dynorad] #2458887
02/28/18 02:37 PM
02/28/18 02:37 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I was having a intermediate shut off issue in my Charger with a 440 Sixpack it turned out to be the bulk head connection at the firewall. Maybe unplug your engine harness, clean all of the connections, make sure that all of the terminals are poking out thru the connectors properly & lube with dielectric grease.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Hemi Shuts off [Re: Jimmy H] #2458893
02/28/18 02:42 PM
02/28/18 02:42 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
what do you by starts but stops quickly?
it fires off and then dies as soon as you turn the key to the run position from the start position?
or it actually runs and then dies??
Re: Hemi Shuts off [Re: dynorad] #2458905
02/28/18 02:56 PM
02/28/18 02:56 PM
usa
Jimmy H Offline OP
Jimmy H  Offline OP
usa
once you get in your 70's you forget stuff. I recall always having one in my cars. Can you test one to see if it works? Also thanks for your help
Re: Hemi Shuts off [Re: Jimmy H] #2458915
02/28/18 03:20 PM
02/28/18 03:20 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Test one what? Ballast resister? Yup, use an ohm meter. Also can be a multimeter.
Unplug the connector on one end of the resister on the car, and test it.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Hemi Shuts off [Re: Jimmy H] #2459008
02/28/18 06:44 PM
02/28/18 06:44 PM
dynorad Offline
dynorad  Offline
The other test you can do is to jumper across it and see if the engine runs. You don't want to let it continue running that way as you could overheat the coil.
It won't run with he ballast unplugged.
Re: Hemi Shuts off [Re: Jimmy H] #2459011
02/28/18 06:56 PM
02/28/18 06:56 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If it starts but dies as soon as you let go of the key, that's a classic sign of a bad ballast resistor. The resistor gets bypassed in the START position. That's why it starts just fine but dies as soon as the ignition switch moves to the RUN position.
It could also be a problem with the bulkhead connector, steering column connector or ignition switch. Use a test light to confirm you have power where you should...when you should. Test the blue wire that's connected to the ballast. You should have power there with the key in the RUN position.
Re: Hemi Shuts off [Re: burdar] #2459074
02/28/18 09:27 PM
02/28/18 09:27 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I've seen this on several e bodies
