moparplate with alternator #2458811
02/28/18 01:13 PM
02/28/18 01:13 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Can you guys post some pics of your motorplate with alternator setups. Looking to go that route in the future and just want to see how others have done their's and what all I might need to do the swap, since I currently use a stock alternator and brackets.
Re: moparplate with alternator [Re: DusterKid] #2458829
02/28/18 01:34 PM
02/28/18 01:34 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
My setup
Re: moparplate with alternator [Re: DusterKid] #2458859
02/28/18 02:05 PM
02/28/18 02:05 PM
AndyF Offline
AndyF  Offline
Re: moparplate with alternator [Re: AndyF] #2458892
02/28/18 02:41 PM
02/28/18 02:41 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine is similar to the others pictured.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: moparplate with alternator [Re: DusterKid] #2458968
02/28/18 05:16 PM
02/28/18 05:16 PM
Alberta,Canada
605ply Offline
605ply  Offline
Alberta,Canada
https://www.dropbox.com/s/b39yjyg1b6q224o/2016-06-13%2019.50.24.jpg?dl=0
this is from a few years back ,i'm not using this anymore....
i didn't have room lower.. worked fine
Re: moparplate with alternator [Re: DusterKid] #2458975
02/28/18 05:27 PM
02/28/18 05:27 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
No picture, but mine was turned around "backwards" with the pulley end towards the back of the car, due to a lack of room, and mounted to a frame rail. An alternator will work running backwards.
Re: moparplate with alternator [Re: DusterKid] #2459007
02/28/18 06:39 PM
02/28/18 06:39 PM
Keymar, MD
Keymar, MD
Will be an A body with stock k frame and BB, so room is limited, so ideas are good.
Re: moparplate with alternator [Re: DusterKid] #2459044
02/28/18 07:58 PM
02/28/18 07:58 PM
AndyF Offline
AndyF  Offline
I have a stock K frame in my BB Duster. The small Denso alternator fits in there just fine.
Re: moparplate with alternator [Re: DusterKid] #2459178
03/01/18 12:22 AM
03/01/18 12:22 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
This is the large body GM 100 amp 1 wire mounted with the Jegs SBC chrome $30 mount in a 63 "B" body.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: moparplate with alternator [Re: DusterKid] #2459277
03/01/18 08:14 AM
03/01/18 08:14 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I cut the adjusting slot into the plate itself. Welded a pivot extension to the water pump housing.
Doug
Re: moparplate with alternator [Re: dvw] #2459285
03/01/18 08:47 AM
03/01/18 08:47 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Super Simple...
