bypassing the T-brake button for reverse #2458147
02/26/18 11:11 PM
02/26/18 11:11 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
First of all I really love my CRT billet probrake, what I am having trouble getting used to holding the button and trying to back up and negotiate the car, if I remember correctly some one had a wiring diagram showing how to wire up the trans reverse light/neutral safety switch to activate the t-brake when in reverse mode, all the while not back feeding into the delay box, anyone still have this diagram handy??
Re: bypassing the T-brake button for reverse [Re: dartman366] #2458163
02/26/18 11:32 PM
02/26/18 11:32 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I just wired in a toggle switch with an indicator light to let me know when it was rev.
Re: bypassing the T-brake button for reverse [Re: dartman366] #2458210
02/27/18 12:41 AM
02/27/18 12:41 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I use the back up light wire to trigger a relay that engages the brake so the car can back up. It also has a trans brake switch that activates the brake, the feed for it is on a toggle switch. My brake will work in first or second and I didn't want to take a chance accidentally bumping the switch when driving it on the street. My two step engages anytime the brake is engaged but it's no problem.
You may have to run the feed wire for the delay box through a toggle switch to keep it from coming on while backing up.
Re: bypassing the T-brake button for reverse [Re: dartman366] #2458241
02/27/18 02:42 AM
02/27/18 02:42 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I vaguely remember seeing that.
If I wanted to do that I would use a 1pole double throw relay (spdt) with the reverse lights activating it.
relay common - brake solenoid
n.c. term - power from delay box brake connection
n.o. term - hot 12volt (line side of delay box)
This would isolate the box when the relay is applied and work normally the rest of the time
Read the rulebook though, about transbrake and 2step connections. Some tech guy could have a problem because you are adding a device into the circuit
"Just a Bracket car dressed up like a streetcar"
Re: bypassing the T-brake button for reverse [Re: dartman366] #2458285
02/27/18 11:32 AM
02/27/18 11:32 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I ran a separate button off the wheel by my switch panel. In a pinch if the steering wheel button fails I can use it in a race also.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: bypassing the T-brake button for reverse [Re: dartman366] #2458320
02/27/18 12:42 PM
02/27/18 12:42 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Use the reverse light micro switch in your shifter to trigger a relay
You can isolate the two circuits by using relays to trigger your transbrake instead of feeding your trans brake directly from the delay box - use the delay box to trigger the 2nd relay
The Bosch/TYCO - Relay, SPST 12Volt/30AMP with diode works good for this purpose
By doing this both circuits are not connected and work independently of each other
Re: bypassing the T-brake button for reverse [Re: dartman366] #2458393
02/27/18 02:24 PM
02/27/18 02:24 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I had 2 buttons hooked up 1 on the steering wheel the other was on a cord under my seat so when I was backing up I can grab that and still be able to steer
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: bypassing the T-brake button for reverse [Re: Just-a-dart] #2458517
02/27/18 06:33 PM
02/27/18 06:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I don't see the need for a relay. The BU light circuit of the 3-prong NSS acts a Normally Open switch so, hooking it from battery power directly to the solenoid would only power the solenoid from that circuit when the shifter is in Reverse.
Having the button and the NSS connected to the solenoid in parallel won't cause any feedback problems unless the button is pressed when in Reverse.
Re: bypassing the T-brake button for reverse [Re: John_Kunkel] #2458556
02/27/18 08:12 PM
02/27/18 08:12 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
True - but the delay box will get back fed and will activate the lock out on the box - so you have to waite to use the trans brake - plus the NSS is not rated for 30 amps - which is what a trans brake can draw
Re: bypassing the T-brake button for reverse [Re: DoubleD] #2458610
02/27/18 10:47 PM
02/27/18 10:47 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I was thinking somewhere in the diagram I was talking about there was a diode involved to prevent that, with my T-brake the button will activate reverse in neutral also so you would just have to remember to put it in neutral and use the T-brake button if you needed to back up on the starting line area, in the pit area it wouldn't matter you just wait for the delay to drop out.
Re: bypassing the T-brake button for reverse [Re: dartman366] #2458708
02/28/18 02:37 AM
02/28/18 02:37 AM
Cab_Burge Online work
Cab_Burge  Online Work
My car had a toggle switch mounted on the shifter down low and up front on the opposite side of the shifter for operating reverse when backing up and or having to turn while backing up when I bought the car, it works great up Almost fool proof, whistling I have forgotten to push it off when I'm in a hurry to get in the staging lanes backing out of my pit spot, it won't go forward with the switch on and the shifter in low gear whistling blush shruggy
My trans brake button is on the steering wheel for hands free from the shifter launches up
Re: bypassing the T-brake button for reverse [Re: dartman366] #2458761
02/28/18 11:20 AM
02/28/18 11:20 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Yes you can put a diode between your box and the the transbrake solenoid - that will do the same thing - but your going to need a 30 amp diode - The diode will stop the back feed to the box when you use your back-up switch
Re: bypassing the T-brake button for reverse [Re: DoubleD] #2458983
02/28/18 05:46 PM
02/28/18 05:46 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
Hi,
my delay box has 2 delays, 2 buttons on wheel left and right side, second button delay is set for 9999 sec. plenty of time to back up smile
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: bypassing the T-brake button for reverse [Re: DoubleD] #2459004
02/28/18 06:26 PM
02/28/18 06:26 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
really? because A typical transbrake solenoid draws 1.4 ohms resistance. 12 volts divided by 1.4 ohms = 8.57 amps! Now check this out... 16 volts divided by the same 1.4 ohms = 11.4 amps!
The formula is one of three "Ohm's Law": V/R=I (the other's are V/I=R & IxR=V) and this simple check will help you decide what size fuse and what gauge wire should be used when wiring your race car or you can ask people on the internet. LOL
Joe
Without Data, you’re just another guy with an opinion.
Re: bypassing the T-brake button for reverse [Re: sr4440] #2459020
02/28/18 07:03 PM
02/28/18 07:03 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I think I said “can” - as most boxes are rated up to up to 30 amps - also a solenoid is actually an inductive circuit - a little different calculation - but hey I am only an electrical engineer
Re: bypassing the T-brake button for reverse [Re: dartman366] #2459027
02/28/18 07:25 PM
02/28/18 07:25 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I try to keep my electrical systems free of unneeded complexity and "stuff". We have a button on the wheel. Push the button and back up. It's a race car. I'm not parallel parking on a busy city street.
Re: bypassing the T-brake button for reverse [Re: CMcAllister] #2459129
02/28/18 11:14 PM
02/28/18 11:14 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
no but sometimes the pit's can get pretty clogged up with car's and trailers and the ocasional dip stick that don't know how to park.
Re: bypassing the T-brake button for reverse [Re: DoubleD] #2459318
03/01/18 11:34 AM
03/01/18 11:34 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Really what is this different calculation?
you might consider telling TCI about your different calculation, because they are doing it wrong.
www.tciauto.com/media/custom/upload/221300-01.pdf
and dedenbear!
http://www.dedenbear.com/TECH_tipTXT1.htm
I have a 15 amp slow blow fuse on mine and have never had a problem.
Joe
Re: bypassing the T-brake button for reverse [Re: DoubleD] #2459380
03/01/18 01:49 PM
03/01/18 01:49 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Yes - and that is why you should put a freewheeling diode across the solenoid..........
Re: bypassing the T-brake button for reverse [Re: dartman366] #2459810
03/02/18 09:11 AM
03/02/18 09:11 AM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
to much brain power for me !! I just push the button.
