Bell Housing Identification Help #2458089
02/26/18 09:38 PM
02/26/18 09:38 PM
Texas
6pkRB Offline OP
6pkRB  Offline OP
Texas
I have a friend that has a bell housing that we are trying to identify what years/engines/body styles this might have been used on. The bearing retainer hole is 4 3/4" but the information he has does not show a 65 or 66 bell housing with that size of bearing retainer hole. The casting number 2468372 shows it is for a 65 or 66 B body.
Any information is appreciated.
Re: Bell Housing Identification Help [Re: 6pkRB] #2458097
02/26/18 09:55 PM
02/26/18 09:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Casting #2468372 should have a 4.354" hole. Somebody has bored it out to use the 4.80" bearing retainer. Not uncommon.
Re: Bell Housing Identification Help [Re: John_Kunkel] #2458121
02/26/18 10:32 PM
02/26/18 10:32 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
If it was stock it would fit a big block A-Body also and be worth good money... work
JB Rhinehart, Realist
A-Body's RULE!
Re: Bell Housing Identification Help [Re: Rhinodart] #2458566
02/27/18 08:49 PM
02/27/18 08:49 PM
Texas
GTS440 Offline
GTS440  Offline
Texas
What's good money?
Re: Bell Housing Identification Help [Re: Rhinodart] #2458649
02/28/18 12:29 AM
02/28/18 12:29 AM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
This is one I have that is an original big block A body bellhousing.
Re: Bell Housing Identification Help [Re: 6pkRB] #2458660
02/28/18 12:43 AM
02/28/18 12:43 AM
Texas
6pkRB Offline OP
6pkRB  Offline OP
Texas
Does the side picture of the one my friend has the same as your A body big block housing? The only difference I see in yours vs his is yours has a casting date on it for 69. His does not have a casting date.
Any idea what his is worth. He probably wants to sell it.
If they did bore it out, they sure did a good job.
Re: Bell Housing Identification Help [Re: 6pkRB] #2460196
03/02/18 10:17 PM
03/02/18 10:17 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
It appears to be the same
Re: Bell Housing Identification Help [Re: GTS440] #2460581
03/03/18 07:10 PM
03/03/18 07:10 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Originally Posted By GTS440
What's good money?
I usually go on line and see what folks are asking.
I have mechanical Aptitude.
I can screw up anything.
