Line lock #2457252
02/25/18 12:50 PM
02/25/18 12:50 PM
usa,pa
jkwedge540 Offline OP
usa,pa
Workin on a 67 Belvedere. I have a morose line lock I want to install. My question is, can I install it between the master cylinder and the proportion valve, or does it have to go after.
Re: Line lock [Re: jkwedge540] #2457335
02/25/18 03:22 PM
02/25/18 03:22 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
before the proportioning/distribution block
Re: Line lock [Re: markz528] #2457461
02/25/18 07:47 PM
02/25/18 07:47 PM
usa,pa
usa,pa
Before the distribution block. Will it work if I put it there?
Re: Line lock [Re: jkwedge540] #2457570
02/25/18 10:43 PM
02/25/18 10:43 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Yes.
Re: Line lock [Re: jkwedge540] #2457676
02/26/18 01:14 AM
02/26/18 01:14 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
The rule book says: "If brake system includes a differential pressure switch, line-loc installed on front brakes must have solenoid installed after the differential switch." I'm pretty sure your 67 has such a switch.
Re: Line lock [Re: Blucuda413] #2457679
02/26/18 01:18 AM
02/26/18 01:18 AM
If your not racing a NHRA class then their rule book does not apply, correct work shruggy One of my old NHRA legal drag race cars had the line lock on the inner fender well between the dual M.C. and the distribution block on the frame, it went through tech a bunch of times at both NHRA National and divisional events that way. The brake light would get bright telling me that the line lock was working fine up grin
Re: Line lock [Re: jkwedge540] #2457730
02/26/18 03:17 AM
02/26/18 03:17 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Mine is mounted between the master cylinder and the distribution block. It’s worked fine for years and has been through tech probably 100 times, never questioned.
Re: Line lock [Re: jkwedge540] #2457864
02/26/18 02:13 PM
02/26/18 02:13 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I agree it may never be checked and it will work but that doesn't make it right. Years ago I did some checking into that rule and was finally convinced it made sense. The result was I removed the dist block totally. I've slept a couple of times since then and can't remember all the details. I do remember I had a hard time even finding out what a differential switch was.
Re: Line lock [Re: jkwedge540] #2457922
02/26/18 04:12 PM
02/26/18 04:12 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Typically it's just a mechanical switch that has the front and rear brakes plumbed through it with a passage between the two with a shuttle valve in it.(or on some later model stuff, it's split diagonally) If pressure is lost on one side while applying the brakes, due to a failed hose, line, etc., the shuttle is supposed to be pushed to the side that has lost pressure and shut it off to prevent total loss of braking. It usually also has an electric switch in it to turn on the brake warning light if actuated.
Installing the front brake line-loc between the MC and the differential switch will cause it to flip and block the rears. Usually you can stab the brakes and get the switch to go back to neutral. Sometimes that doesn't work and other methods have to be used.
Some people pull that stuff off when using any aftermarket or non-OE brake components. Some don't.
Re: Line lock [Re: StealthWedge67] #2457930
02/26/18 04:25 PM
02/26/18 04:25 PM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Line lock [Re: jkwedge540] #2458533
02/27/18 07:10 PM
02/27/18 07:10 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I was just wondering the reason for this a couple weeks ago. I need to do a new brake line across the firewall while I have the engine out and part of me wanted to buy a fancy prebent stainless line. I was curious if it's really necessary to follow the instructions, blocking off one outlet and T off the line lock. I guess I'll just follow the instructions.
