Re: Line lock
[Re: jkwedge540]
#2457335
02/25/18 03:22 PM
02/25/18 03:22 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
before the proportioning/distribution block
Re: Line lock
[Re: jkwedge540]
#2457730
02/26/18 03:17 AM
02/26/18 03:17 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Mine is mounted between the master cylinder and the distribution block. It’s worked fine for years and has been through tech probably 100 times, never questioned.
Re: Line lock
[Re: jkwedge540]
#2457922
02/26/18 04:12 PM
02/26/18 04:12 PM
Posts: 11,569 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Typically it's just a mechanical switch that has the front and rear brakes plumbed through it with a passage between the two with a shuttle valve in it.(or on some later model stuff, it's split diagonally) If pressure is lost on one side while applying the brakes, due to a failed hose, line, etc., the shuttle is supposed to be pushed to the side that has lost pressure and shut it off to prevent total loss of braking. It usually also has an electric switch in it to turn on the brake warning light if actuated.
Installing the front brake line-loc between the MC and the differential switch will cause it to flip and block the rears. Usually you can stab the brakes and get the switch to go back to neutral. Sometimes that doesn't work and other methods have to be used.
Some people pull that stuff off when using any aftermarket or non-OE brake components. Some don't.
Re: Line lock
[Re: StealthWedge67]
#2457930
02/26/18 04:25 PM
02/26/18 04:25 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
