Re: Getting mixed feelings on Penn Grade Oil
[Re: Sammy]
#2457898
02/26/18 03:26 PM
02/26/18 03:26 PM
Posts: 4,457 Washington
madscientist
Washington
Very few oils are the cause of engine issues. I've never used Brad Penn but I have a hard time believing the oil is an issue, unless they are using the wrong oil for the application.
Most of the boutique oil manufacturers make 7-8 different oils in many many grades. Could be they are using the incorrect oil for the job.
[Re: Sammy]
#2457899
02/26/18 03:28 PM
02/26/18 03:28 PM
Posts: 14,497 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Plenty of other choices if you're not comfortable with the Penn Grade stuff.
Driven Red Line Royal Purple Torco Champion Lucas
To name a few
[Re: fast68plymouth]
#2457904
02/26/18 03:34 PM
02/26/18 03:34 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
To name a few Driven oil was recommended to me now from a reputable source thanks
[Re: Sammy]
#2457917
02/26/18 04:07 PM
02/26/18 04:07 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I'm planning on ditching the Brad Penn for this...... http://www.schaefferoil.com/racing.htmlI had heard the Brad Penn has changed a bit since the company was sold. Can't verify this though.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Sammy]
#2457928
02/26/18 04:23 PM
02/26/18 04:23 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
LOL, all the while there are tons of engines making big power on parts store bought Valvoline, Mobil One, etc.
[Re: Sammy]
#2457960
02/26/18 05:32 PM
02/26/18 05:32 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Lucas hot rod oil is the best stuff i have ever used. Easily
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Sammy]
#2458058
02/26/18 08:32 PM
02/26/18 08:32 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I stopped using Brad Penn oil, and went to Schaeffers and Driven. Thats all I am going to say.
RIP Monte Smith
[Re: CompWedgeEngines]
#2458060
02/26/18 08:38 PM
02/26/18 08:38 PM
Sammy
Wind Gap,Pa.
I stopped using Brad Penn oil, and went to Schaeffers and Driven. Thats all I am going to say. Which Driven oil, theres a few different types. I'm thinking 5W30
[Re: Chuck@Best_Machine]
#2458332
02/27/18 12:56 PM
02/27/18 12:56 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Many of my buddies run Brad Penn. The stuff feels slippery & doesn't like to come off of your skin but I have never been a fan either for the money. I just run whatever brand oil 10W30 is on sale at that moment when I am in the parts store. Never had an issue with any of them.
At work we just run 10W30 conventional in all of our crate engines & for the race engines we use the Rotella 15W40 Diesel oil.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 70satelliteguy]
#2458381
02/27/18 02:03 PM
02/27/18 02:03 PM
Posts: 1,070 Big Western Pencilveinya
Uncle Barry
"Many of my buddies run Brad Penn. The stuff feels slippery & doesn't like to come off of your skin but I have never been a fan either for the money. I just run whatever brand oil 10W30 is on sale at that moment when I am in the parts store. Never had an issue with any of them.
" for the race engines we use the Rotella 15W40 Rotella Diesel oil."
Agree with all of the above!!
Mike I run the same but also put some Lucas break in additive with it at each oil change.
#2458400
02/27/18 02:35 PM
02/27/18 02:35 PM
BradH
I stopped using Brad Penn oil, and went to Schaeffers and Driven. Thats all I am going to say. Considering you used to be one of the Brad Penn proponents, that a significant statement even without any further comments.
[Re: Sammy]
#2458405
02/27/18 02:41 PM
02/27/18 02:41 PM
BradH
I heard Brad Penn had a tendency to burn pushed tips same with Royal Purple Racing 21 oil. I heard it causes hemorrhoids, too, but do my best to filter out a lot of "static" I hear. We broke in my engine on "legacy" Brad Penn 30 break-in, but I've got 7 quarts of Driven Hot Rod 10w40 conventional ready to replace it when I drain the pan. There's also some Amsoil on my oil shelf that will get used if/when I decide to start using synthetics, again.
[Re: B3422W5]
#2458411
02/27/18 02:48 PM
02/27/18 02:48 PM
BradH
Lucas hot rod oil is the best stuff i have ever used. Easily My issue w/ Lucas, and it could be completely irrational, is that I suspect their Marketing Dept has as much influence on what goes into their oils as their Engineering Dept. Have you seen some of the ZDDP #s they put in some of their oils? They are waaaaay off the "reasonable amount" scale and jumping right into the "too much of anything is NOT a good thing" range. It also appeared for quite a while that Lucas must have been giving sh!tloads of free product (or buying sh!tloads of advertising) to all the major magazines -- at least the ones that are left -- since virtually every dyno test article they ran used Lucas oil. I'll pass, thanks.
[Re: BradH]
#2458447
02/27/18 04:06 PM
02/27/18 04:06 PM
B3422W5
Portage,michigan
Lucas hot rod oil is the best stuff i have ever used. Easily My issue w/ Lucas, and it could be completely irrational, is that I suspect their Marketing Dept has as much influence on what goes into their oils as their Engineering Dept. Have you seen some of the ZDDP #s they put in some of their oils? They are waaaaay off the "reasonable amount" scale and jumping right into the "too much of anything is NOT a good thing" range. It also appeared for quite a while that Lucas must have been giving sh!tloads of free product (or buying sh!tloads of advertising) to all the major magazines -- at least the ones that are left -- since virtually every dyno test article they ran used Lucas oil. I'll pass, thanks. Your right.... lol...... might be completely irrational I love the stuff, read lot of reviews from guys who have been using it a few years. Great on cold startups after car has sat, clings really well
