Page 1 of 4 1 2 3 4
Getting mixed feelings on Penn Grade Oil #2457892
02/26/18 03:02 PM
02/26/18 03:02 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
So I am hearing now from a few reputable engine builders that Penn Grade semi synthetic oil is not the go to oil these days and they are having problems with it.
They said on some of their high end builds, the oil is not working out and they are burning up parts.
I need to buy oil and now not sure if the non synthetic dino oil is the way to go.
Any thoughts?
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2457898
02/26/18 03:26 PM
02/26/18 03:26 PM
Washington
madscientist Offline
Washington
Very few oils are the cause of engine issues. I've never used Brad Penn but I have a hard time believing the oil is an issue, unless they are using the wrong oil for the application.
Most of the boutique oil manufacturers make 7-8 different oils in many many grades. Could be they are using the incorrect oil for the job.
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2457899
02/26/18 03:28 PM
02/26/18 03:28 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Plenty of other choices if you're not comfortable with the Penn Grade stuff.
Driven
Red Line
Royal Purple
Torco
Champion
Lucas
To name a few
Re: Getting mixed feelings on Penn Grade Oil [Re: fast68plymouth] #2457904
02/26/18 03:34 PM
02/26/18 03:34 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Driven
Red Line
Royal Purple
Torco
Champion
Lucas
To name a few
Driven oil was recommended to me now from a reputable source thanks
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2457917
02/26/18 04:07 PM
02/26/18 04:07 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I'm planning on ditching the Brad Penn for this......
http://www.schaefferoil.com/racing.html
I had heard the Brad Penn has changed a bit since the company was sold. Can't verify this though.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2457926
02/26/18 04:19 PM
02/26/18 04:19 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Which Driven oil would be the one to get?
I like 5W30 looks like it's a Joe Gibbs product
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2457928
02/26/18 04:23 PM
02/26/18 04:23 PM
an8sec70cuda Offline
LOL, all the while there are tons of engines making big power on parts store bought Valvoline, Mobil One, etc.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2457960
02/26/18 05:32 PM
02/26/18 05:32 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Lucas hot rod oil is the best stuff i have ever used. Easily
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2457966
02/26/18 05:43 PM
02/26/18 05:43 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I wish Best Machine would chime in on this one, they seem to make horse power and I'm pretty sure they don't use it anymore especially in their high end builds.
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2458058
02/26/18 08:32 PM
02/26/18 08:32 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I stopped using Brad Penn oil, and went to Schaeffers and Driven. Thats all I am going to say.
RIP Monte Smith
Re: Getting mixed feelings on Penn Grade Oil [Re: CompWedgeEngines] #2458060
02/26/18 08:38 PM
02/26/18 08:38 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Which Driven oil, theres a few different types. I'm thinking 5W30
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2458315
02/27/18 12:30 PM
02/27/18 12:30 PM
Farmington Hills, Mich
Chuck@Best_Machine Offline
We stopped using BP years ago. A lot of the Engines that come in for freshen ups that run BP have worn rocker shafts and Piston Pins. We only use Driven Brand Oil, every Big Block we Dyno has BR50 in it. In a lot of our high HP Drag engine we use XP3 after dyno but in most cases the HR series oil is a good choice. We use the 15/50 in our bracket style engines.
Re: Getting mixed feelings on Penn Grade Oil [Re: Chuck@Best_Machine] #2458332
02/27/18 12:56 PM
02/27/18 12:56 PM
Motor City
6PKRTSE Online content
6PKRTSE  Online Content
Motor City
Many of my buddies run Brad Penn. The stuff feels slippery & doesn't like to come off of your skin but I have never been a fan either for the money. I just run whatever brand oil 10W30 is on sale at that moment when I am in the parts store. Never had an issue with any of them.
At work we just run 10W30 conventional in all of our crate engines & for the race engines we use the Rotella 15W40 Diesel oil.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Getting mixed feelings on Penn Grade Oil [Re: 6PKRTSE] #2458355
02/27/18 01:33 PM
02/27/18 01:33 PM
Penna
70satelliteguy Offline
Penna
"Many of my buddies run Brad Penn. The stuff feels slippery & doesn't like to come off of your skin but I have never been a fan either for the money. I just run whatever brand oil 10W30 is on sale at that moment when I am in the parts store. Never had an issue with any of them.
" for the race engines we use the Rotella 15W40 Rotella Diesel oil."
Agree with all of the above!!
Mike
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2458375
02/27/18 01:57 PM
02/27/18 01:57 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I heard Brad Penn had a tendency to burn pushed tips same with Royal Purple Racing 21 oil.
Re: Getting mixed feelings on Penn Grade Oil [Re: 70satelliteguy] #2458381
02/27/18 02:03 PM
02/27/18 02:03 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
Mike
I run the same but also put some Lucas break in additive with it at each oil change.
Re: Getting mixed feelings on Penn Grade Oil [Re: CompWedgeEngines] #2458400
02/27/18 02:35 PM
02/27/18 02:35 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Considering you used to be one of the Brad Penn proponents, that a significant statement even without any further comments.
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2458405
02/27/18 02:41 PM
02/27/18 02:41 PM
BradH Offline
BradH  Offline
I heard it causes hemorrhoids, too, but do my best to filter out a lot of "static" I hear.
We broke in my engine on "legacy" Brad Penn 30 break-in, but I've got 7 quarts of Driven Hot Rod 10w40 conventional ready to replace it when I drain the pan.
There's also some Amsoil on my oil shelf that will get used if/when I decide to start using synthetics, again.
Re: Getting mixed feelings on Penn Grade Oil [Re: B3422W5] #2458411
02/27/18 02:48 PM
02/27/18 02:48 PM
BradH Offline
BradH  Offline
My issue w/ Lucas, and it could be completely irrational, is that I suspect their Marketing Dept has as much influence on what goes into their oils as their Engineering Dept. Have you seen some of the ZDDP #s they put in some of their oils? They are waaaaay off the "reasonable amount" scale and jumping right into the "too much of anything is NOT a good thing" range. down
It also appeared for quite a while that Lucas must have been giving sh!tloads of free product (or buying sh!tloads of advertising) to all the major magazines -- at least the ones that are left -- since virtually every dyno test article they ran used Lucas oil. work
I'll pass, thanks.
Re: Getting mixed feelings on Penn Grade Oil [Re: BradH] #2458447
02/27/18 04:06 PM
02/27/18 04:06 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I'll pass, thanks.
Your right.... lol...... might be completely irrational
I love the stuff, read lot of reviews from guys who have been using it a few years.
Great on cold startups after car has sat, clings really well
1.41 best 60 foot
6.60 at 103.90 1/8
Page 1 of 4 1 2 3 4
