Milling pockets in pistons #2457616
02/25/18 11:43 PM
02/25/18 11:43 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
I have a set of Speed Pro 360 .030 over pistons that I am considering milling a small pocket to decrease compression. The rotating assembly has been balanced so I am concerned with that. There pockets are small so the weight will be small but not sure how it will affect things. Any comments?
I don't know much about balancing.
Re: Milling pockets in pistons [Re: mopfried] #2457623
02/25/18 11:50 PM
02/25/18 11:50 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Dont know how much of a decrease in comp your wanting but maybe you can try thicker head gasket.
Cometic can make just about any thickness you need.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Milling pockets in pistons [Re: mopfried] #2457639
02/26/18 12:13 AM
02/26/18 12:13 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Before you consider a hick gasket, what's your quench distance now? If it's at .060", you lose it completely with a thicker gasket.
If you have .035-40", it will be less effective but still active.
Your bob weight will change by 50% of the weight change.
Boffin Emeritus
Re: Milling pockets in pistons [Re: mopfried] #2457646
02/26/18 12:25 AM
02/26/18 12:25 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
That's my problem. My chambers are too small with quench at a .030-.035". Instead of using different heads i was considering milling a small pocket, maybe 6cc or so.
The deck is .005 in the hole with a 58cc closed chamber iron head. too much compression with quench.
Not sure what you mean by "Your bob weight will change by 50% of the weight change."
I guess I need to do some calculations to see just what size pocket I need to mill to figure how many grams weight change will be.
Re: Milling pockets in pistons [Re: mopfried] #2457660
02/26/18 12:49 AM
02/26/18 12:49 AM
Alberta
440_Offroader Offline
Alberta
Just throwing this out there. What about increasing your cylinder head cc, like deshrouding the intake valve. Not sure what heads you have if it's feasible or not.
Re: Milling pockets in pistons [Re: mopfried] #2457666
02/26/18 01:02 AM
02/26/18 01:02 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
To play with the numbers try the compression formula on the Diamond site. You can play with combustion chamber, head gasket thickness, piston dish, etc. You can figure out exactly what you need to do.
Re: Milling pockets in pistons [Re: 440_Offroader] #2457675
02/26/18 01:13 AM
02/26/18 01:13 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
This is what I would do before messing with the pistons, that and maybe more thickness of the head gasket if you don't lose quench.
Re: Milling pockets in pistons [Re: mopfried] #2457687
02/26/18 01:25 AM
02/26/18 01:25 AM
Washington
madscientist Offline
Washington
How much compression do you have?
Re: Milling pockets in pistons [Re: mopfried] #2457695
02/26/18 01:36 AM
02/26/18 01:36 AM
Kirkland, Washington
Pacnorthcuda Offline
Your pistons are .005 in the hole and you have .030-.035 quench??? Then that's already using a thin head gasket. Or are your Pistons standing .005 ABOVE the deck?
Re: Milling pockets in pistons [Re: mopfried] #2457701
02/26/18 02:01 AM
02/26/18 02:01 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
.005 under the deck or in the hole. The heads are some old W-2 ported open chamber heads with 70cc. no quench and low compression. I thought about milling .050 off them to make them closed chambered. but that puts the cc's about 56-58. but with a thin gasket and the piston in the hole .005 I coukd possibly deshroud the valves and get more chamber cc's. I haven set a head gasket on there yet to see how much deshrouding i can do.
Re: Milling pockets in pistons [Re: mopfried] #2457728
02/26/18 03:10 AM
02/26/18 03:10 AM
New York
polyspheric Offline
polyspheric  Offline
New York
I'd certainly look at unshrouding the valves. It's a lot of work (and should all be really close) but where and how much depends on the shape now, valve lift, stem angle, blah. Sometimes too open is a mistake, the flow leaving the seat wants to expand gradually and in the right direction, not turned loose all at once (like a vertical valve).
I wrote some stuff on the subject, some of it may be relevant: http://victorylibrary.com/mopar/chamber-tech.htm
Got a picture of a chamber?
Boffin Emeritus
Re: Milling pockets in pistons [Re: mopfried] #2457808
02/26/18 12:18 PM
02/26/18 12:18 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
I re-checked my calculations. I am right a 10.13 with a 70 cc head and no quench (.080). That is with a .027 thick gasket. If I mill .050 off the head the compression will go up 1 point. I believe that is too much for a iron head on pump gas. I read the info Polyspheric posted..... good info. I will buy a head gasket and see what I can come up with. Playing with the numbers I need roughly 10-11 cc less than I have if I mill the head to be closed chambered and have .033-.035" quench.
Re: Milling pockets in pistons [Re: mopfried] #2458068
02/26/18 09:05 PM
02/26/18 09:05 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
Should I just leave it alone?
Re: Milling pockets in pistons [Re: mopfried] #2458183
02/26/18 11:53 PM
02/26/18 11:53 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Where did you think you were? Iron heads, 9.5 comp is the safe rule of thumb. If it were me , id go for quench, mill .030/.040 and then deshroud the head. I haven't done any of the math except the quench, trusting you on the comp figure. But quench is always better if its in range and you can figure out how to get it.
Re: Milling pockets in pistons [Re: mopfried] #2458506
02/27/18 06:08 PM
02/27/18 06:08 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
9.5:1 on a small block with iron heads is pretty conservative. But a lot of it comes down to how tight the quench is, and how big the cam is. I can tell you that I ran an open chambered iron head at 12.2:1 and .030"~.035" quench on pump gas without issues. This was done by equalizing the chamber depth on each hole, and milling the block to put the pistons .070" out of the hole. VERY unconventional way of doing it. I'd be leery to mill .050" off the heads unless you were sure that the deck was nice and thick to start with.
How deep is the chamber right now on the quench side of your heads?
Honestly if the cam is big enough, the 10.1:1 will probably fly ok without detonating. Worst case scenario you knock a few degree's of timing out of it on the street, and put a splash of race gas and full timing at the track.
The best thing you could do is to buy a set of quench dome pistons and re-balance, but it's also your most expensive option so I can see why you might not want to.
Re: Milling pockets in pistons [Re: mopfried] #2458546
02/27/18 07:47 PM
02/27/18 07:47 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Call rebco machine, think he is Wichita. He cut deeper pockets in two sets of my pistons. He does great work.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Milling pockets in pistons [Re: mopfried] #2458558
02/27/18 08:19 PM
02/27/18 08:19 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A slight change in top end weight won't do any harm.
Re: Milling pockets in pistons [Re: mopfried] #2458569
02/27/18 09:02 PM
02/27/18 09:02 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
The quench side of the wedge shape is right around .050" deep. The deck has been cut to put the pistons .005" in the hole.
Re: Milling pockets in pistons [Re: mopfried] #2458641
02/28/18 12:09 AM
02/28/18 12:09 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
I want to post a pic of the chamber but do not understand how to do it.
Re: Milling pockets in pistons [Re: mopfried] #2458770
02/28/18 11:44 AM
02/28/18 11:44 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
