Re: Milling pockets in pistons
[Re: mopfried]
#2457623
02/25/18 11:50 PM
02/25/18 11:50 PM
Posts: 289 Lowes
steve660
Lowes
Dont know how much of a decrease in comp your wanting but maybe you can try thicker head gasket. Cometic can make just about any thickness you need.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: mopfried]
#2457639
02/26/18 12:13 AM
02/26/18 12:13 AM
Posts: 4,206 New York
polyspheric
New York
Before you consider a hick gasket, what's your quench distance now? If it's at .060", you lose it completely with a thicker gasket. If you have .035-40", it will be less effective but still active. Your bob weight will change by 50% of the weight change.
Boffin Emeritus
[Re: 440_Offroader]
#2457675
02/26/18 01:13 AM
02/26/18 01:13 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Just throwing this out there. What about increasing your cylinder head cc, like deshrouding the intake valve. Not sure what heads you have if it's feasible or not. This is what I would do before messing with the pistons, that and maybe more thickness of the head gasket if you don't lose quench.
[Re: mopfried]
#2457687
02/26/18 01:25 AM
02/26/18 01:25 AM
Posts: 4,457 Washington
madscientist
Washington
How much compression do you have?
[Re: mopfried]
#2457728
02/26/18 03:10 AM
02/26/18 03:10 AM
polyspheric
New York
I'd certainly look at unshrouding the valves. It's a lot of work (and should all be really close) but where and how much depends on the shape now, valve lift, stem angle, blah. Sometimes too open is a mistake, the flow leaving the seat wants to expand gradually and in the right direction, not turned loose all at once (like a vertical valve). I wrote some stuff on the subject, some of it may be relevant: http://victorylibrary.com/mopar/chamber-tech.htmGot a picture of a chamber?
Boffin Emeritus
[Re: mopfried]
#2458183
02/26/18 11:53 PM
02/26/18 11:53 PM
Sport440
Canton, Ohio
I re-checked my calculations. I am right a 10.13 with a 70 cc head and no quench (.080). That is with a .027 thick gasket. If I mill .050 off the head the compression will go up 1 point. I believe that is too much for a iron head on pump gas. I read the info Polyspheric posted..... good info. I will buy a head gasket and see what I can come up with. Playing with the numbers I need roughly 10-11 cc less than I have if I mill the head to be closed chambered and have .033-.035" quench. Where did you think you were? Iron heads, 9.5 comp is the safe rule of thumb. If it were me , id go for quench, mill .030/.040 and then deshroud the head. I haven't done any of the math except the quench, trusting you on the comp figure. But quench is always better if its in range and you can figure out how to get it.
[Re: mopfried]
#2458546
02/27/18 07:47 PM
02/27/18 07:47 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Call rebco machine, think he is Wichita. He cut deeper pockets in two sets of my pistons. He does great work.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
