800hp hemi rods #2457504
02/25/18 08:52 PM
02/25/18 08:52 PM
Temperance, MI
68 HEMI GTS Offline OP
Temperance, MI
What are you guys using? Lookin to make 800-850. 4.5” crank with a 7.100 rod. Street/strip motor.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: 800hp hemi rods [Re: 68 HEMI GTS] #2457520
02/25/18 09:12 PM
02/25/18 09:12 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I had Manley h beams when I sent my hemi out to be redone.Builder made a mistake on the replacement 4.5 stroke crank and said he would replace the rod due to me having chevy ends and the Callies crank he bought had Chrysler ends.After 5 years I had to freshen it again and found Eagle rods.Checked and they are good to 1500 HP.
Buy the best your wallet will allow!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 800hp hemi rods [Re: hemi-itis] #2457573
02/25/18 10:47 PM
02/25/18 10:47 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Eagle rods here with ARP 2000 bolts. They take a beating...
Callies now makes a billet 7.1 rod..I have never run those.
The super stock guys all run Oliver rods with Bryant cranks. Those guys are not easy on parts...
Re: 800hp hemi rods [Re: 68 HEMI GTS] #2457593
02/25/18 11:22 PM
02/25/18 11:22 PM
AndyF Offline
AndyF  Offline
If you are using 7.10 long rods with 2.200 and 0.990 ends then there will be a ton of choices. My guess is that any 7.100 long rod made will handle 800 hp. That size isn't popular enough to attract the real bottom feeder crowd. If it is a budget engine I'd use Molnar or SCAT. If the budget is more generous then step up to Oliver or Callies. I doubt I'd use Crower or Carrillo or anything like that unless it was a LSR application.
Re: 800hp hemi rods [Re: 68 HEMI GTS] #2457637
02/26/18 12:10 AM
02/26/18 12:10 AM
New York
polyspheric Offline
polyspheric  Offline
New York
This^^^, and get the best fasteners.
X2 on Molnar for best value
Boffin Emeritus
Re: 800hp hemi rods [Re: 68 HEMI GTS] #2457648
02/26/18 12:33 AM
02/26/18 12:33 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've got about 180 passes on my Molnar 7.100/2.200/.990 in my wedge. Nice ARP 2000 bolts. Bearings look perfect during this check. Balance was with-in 1 gram all machining was with-in .000x. Paid less than $600 shipped.
Doug
Re: 800hp hemi rods [Re: dvw] #2457683
02/26/18 01:20 AM
02/26/18 01:20 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have Ray Barton 7.100 rods made by Manley for my 528" Hemi. Also using a Molnar crank.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 800hp hemi rods [Re: 68 HEMI GTS] #2457731
02/26/18 03:18 AM
02/26/18 03:18 AM
New York
polyspheric Offline
polyspheric  Offline
New York
After good reports from other owners, I'm using Molnars in my turbo Toyota L6 street car, but it's not together yet.
3 liter = 183"
8.5:1 static CR
Stock GTE (factory turbo) head, block, crank, main caps, oil system, pan
PT6466 turbo, 35 psi
HKS "mini" 264° cams
Est. 800 hp @ 7,500
or not!
Boffin Emeritus
Re: 800hp hemi rods [Re: 68 HEMI GTS] #2457746
02/26/18 04:47 AM
02/26/18 04:47 AM
What block? Can you afford to have a cheap rod break and have to replace the block? If not buy the best overkill rod you can get work up twocents
BTW, a really light weight piston and wristpin will add greatly to the rods usable life span work scope up
I'm buying parts now for a N/A 1000+HP Koleno block 555 C.I. wedge motor with B1-MC heads, not sure on which rods it will get yet confused
Not cheap ones though tsk
Re: 800hp hemi rods [Re: 68 HEMI GTS] #2457799
02/26/18 11:45 AM
02/26/18 11:45 AM
an8sec70cuda Offline
I have Oliver steel rods in my 572" hemi.
I have a set of Molnar rods for my dad's 540" hemi (not built yet). With more cam and ported heads, it'd be right w/ mine as far as power.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 800hp hemi rods [Re: an8sec70cuda] #2457851
02/26/18 01:34 PM
02/26/18 01:34 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Callies Ultra Ibeams in my 572 HEMI - started with Molnars - but for a little more piece of mind went with Callies - If you go Molnars upgrade to the L19 rod bolts if available
