Smoking left bank #2456523
02/24/18 04:12 AM
02/24/18 04:12 AM
Cotati, CA
Dave Hall Offline OP
Cotati, CA
'64 300 with a 413 4bbl. completely stock. Oil smokes from the left exhaust and progressively gets worse with temp. I thought it might be hard valve seals from sitting. Any other idea's? Experiences?
Re: Smoking left bank [Re: Dave Hall] #2456528
02/24/18 04:44 AM
02/24/18 04:44 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Valve seals are a good place to start,do a compression test as well as a leak down test too.The intake bathtub gasket could be letting oil get sucked into the ports if it is old and corroded or loose manifold bolts.The steel shim head gasket could be bad near the oil galley to the head allowing oil into a cylinder or two,the head bolts could be relieved of tension as well reducing clamping pressure.
RT
Re: Smoking left bank [Re: RTSrunner] #2456532
02/24/18 05:18 AM
02/24/18 05:18 AM
Cotati, CA
Cotati, CA
Thanks! Yeah, it's old but runs sweet. Starts right up and gets quietly down the road. I've never heard of head bolts losing tension but if I'm taking the rockers off to replace the valve seals won't hurt to throw a tq wrench on them.
Re: Smoking left bank [Re: Dave Hall] #2456537
02/24/18 06:00 AM
02/24/18 06:00 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Valve seals for sure, do them first and see what it does. Intake gasket sure could do it. Pretty easy to change it second.
Re: Smoking left bank [Re: Dave Hall] #2456721
02/24/18 03:54 PM
02/24/18 03:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
Make sure and remove the broken pieces of the old valve seals from the top of the motor, including as far as removing the intake and valley pan twocents scope
Years ago, back in the mid 1960s, I lost a oil pump on my 1957 Chrysler 300C due to the old OEM valve oil seals breaking apart in to small pieces from being brittle and part of one getting sucked up into the oil pump twisting the oil pump drive shaft off whiney I was in Utah visiting my Mother and Sister with my family in the middle of winter 800 miles from home so I had to pay a local shop to do the repairs shruggy They did a good job at a reasonable price but a break down is never fun, no matter where and when work
Preventive maintenance is way better than having to fix it after it is broken work grin
Re: Smoking left bank [Re: Dave Hall] #2456808
02/24/18 05:52 PM
02/24/18 05:52 PM
Chicago
PurpleBeeper Offline
Chicago
I have to say the intake gasket (bathtub) or the valve seals...."maybe" the guides are likely causing your problem. You might be able to narrow it down by pulling the spark plugs on that side & looking for an oily one.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Smoking left bank [Re: Dave Hall] #2456833
02/24/18 06:21 PM
02/24/18 06:21 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
With the rockers off a leak-down test is easy since all the valves are closed.
Re: Smoking left bank [Re: Dave Hall] #2457027
02/24/18 11:34 PM
02/24/18 11:34 PM
Cotati, CA
Cotati, CA
Thanks for all of the above. It's a sweet, old 1964 300. I'll get into it and update what I find. Thanks again! up
Re: Smoking left bank [Re: PurpleBeeper] #2457105
02/25/18 01:35 AM
02/25/18 01:35 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
This ^^^ and maybe try pulling one plug lead off at a time letting it run for a bit, the smoke will stop when you have the right lead off.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Smoking left bank [Re: ozymaxwedge] #2457149
02/25/18 04:07 AM
02/25/18 04:07 AM
Cotati, CA
Cotati, CA
Good call Ozy! I'll try that first thing!
Re: Smoking left bank [Re: Dave Hall] #2457242
02/25/18 12:35 PM
02/25/18 12:35 PM
God's Country Maryland
GODSCOUNTRY340 Offline
I had a '74 Powerwagon with a 360 that was doing the same thing. Ended up being rings stuck in the ring lands. It was easy to pinpoint because that cylinder would quickly oil foul the spark plug and the smoking would stop, though it would miss and only run on 7 cylinders.
Re: Smoking left bank [Re: GODSCOUNTRY340] #2457375
02/25/18 04:57 PM
02/25/18 04:57 PM
Cotati, CA
Cotati, CA
This thing is smooth and doesn't miss, I'll try pulling a plug wire on 1-7 and see if it's limited to one cylinder. It'll be next week some time as the car is two hours away from me.
Re: Smoking left bank [Re: Dave Hall] #2479372
04/08/18 01:12 PM
04/08/18 01:12 PM
Cotati, CA
Cotati, CA
I finally got to work on the car this weekend and replaced the rock hard valve stem seals. I put new plugs in it and checked the tune. The smoke has nearly disappeared and the car runs and drives as it should. I believe that this car has the original valve springs as they still have the red paint for exhaust and green paint for intake on them. I couldn't get any movement in the guides so the owner is super happy and I made a few bucks! Thanks to TorqueFlights by Wessels for the leak down tester and Paul's Empire Heads for the seals in a pinch!
Re: Smoking left bank [Re: Dave Hall] #2479378
04/08/18 01:16 PM
04/08/18 01:16 PM
Cotati, CA
Cotati, CA
Wow! Sorry for the flipped pic...
Re: Smoking left bank [Re: Dave Hall] #2479408
04/08/18 02:05 PM
04/08/18 02:05 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Posting with an Apple product? I've no idea why that happens, it showed up fine on my computer (not the browser, that was upside down), something about the way Apple formats pictures? shruggy
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Smoking left bank [Re: Dave Hall] #2479412
04/08/18 02:08 PM
04/08/18 02:08 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Looking at that picture.... Now we know why it smoked...lol
Rice ride... smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Smoking left bank [Re: Dave Hall] #2479414
04/08/18 02:11 PM
04/08/18 02:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Car looks great and those wheels really set it off. up
Re: Smoking left bank [Re: stumpy] #2479433
04/08/18 02:42 PM
04/08/18 02:42 PM
Cotati, CA
Cotati, CA
Thanks for the fix Robert! Yep, just easier for me to post pics that are already on my iPhone. This is the first time I've seen it go 180* though... It's kind of cool for an ugly old car! The front bumper needs attention and it's missing the rocker molding on both sides. If anyone has them or knows where to get them it would be much appreciated! The doors are really short for a two door. I'm used to those big, old 5 foot doors! It has power windows and some cool original features. It's a "Silver Edition"??? The vinyl top pattern is unique and very cool. Everything works!
Re: Smoking left bank [Re: Dave Hall] #2479475
04/08/18 03:51 PM
04/08/18 03:51 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Glad to hear you fixed it easily. Those wheels look great on that car. There has been a crew cab like your car for sale near me forever. I may have to snag it to put these style wheels on it now.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Smoking left bank [Re: Dave Hall] #2479480
04/08/18 03:58 PM
04/08/18 03:58 PM
Cotati, CA
Cotati, CA
It's a nice ride with the split bench! We need the rocker moldings and the wheel lip moldings! Anyone???
