fuel priming bulb for car that sits often? #2456453
02/24/18 01:07 AM
02/24/18 01:07 AM
Oklahoma
Mopar72Man Offline OP
Oklahoma
I have a 70s dodge that gets driven one a month with a 360.
I would like to be able to prime the edelbrock with fuel but don't particularly want to deal with an electronic pump of any sort.
Has anyone used a typical marine priming bulb? I figure a few squeezes under the hood and i should get a head start on it.
72 Challenger - will be sublime, little 340 904, 8 3/4" - Under Construction
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2456456
02/24/18 01:15 AM
02/24/18 01:15 AM
Kirkland, Washington
Pacnorthcuda Offline
There is the temperature fire hazard issue, and I am not sure that suction on the line can pull through a standard mechanical pump???
If it can/will, and you make it safe (!!!!!!) it might work.
Less convenient is to pull the cleaner cover and squirt gas into the bowl vent.
Or starting fluid of course.
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2456460
02/24/18 01:19 AM
02/24/18 01:19 AM
You would also want to test your "pump" by pulling fluid (water?) through it to make sure it's not restrictive to the system during normal operation.
How are you going to POSITIVELY ensure that rubber bellows doesn't melt on a hard run hot day?
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2456466
02/24/18 01:33 AM
02/24/18 01:33 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Damn! Bringing me back to the old family boat/Evinrude days! grin How about a tee with a valve in the fuel line to the carb? Then hook the bellows up to a gas can if you need to? Maybe one of these with a cap? I know that the guys racing in Stock have a slicker unit because NHRA checks their fuel all the time...I just don't know what it is???
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2456473
02/24/18 01:44 AM
02/24/18 01:44 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I use an old plastic mustard bottle, cleaned well with gas in it.
Short squirt in carb & crank.
Take all normal safety precautions of course.
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2456503
02/24/18 02:55 AM
02/24/18 02:55 AM
Dr Dave Offline
Dr Dave  Offline
Even more a pita with a shaker setup. Lots to remove to get to carbs.
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2456505
02/24/18 03:02 AM
02/24/18 03:02 AM
I use a plastic horse syringe with no needle, fill it and squirt some in the carb, not a BUNCH tsk
3 or 4 CC will make them start right up up scope
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2456574
02/24/18 11:16 AM
02/24/18 11:16 AM
jersey
Spaceman Spiff Offline
jersey
I don’t think you should have to prime the carb on something that gets driven once a month.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2456585
02/24/18 11:48 AM
02/24/18 11:48 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
On a boat motor, those bulbs are meant to be on the suction side. You want to pressurize it with fuel coming out of the mechanical pump? On the suction side, if there's any obstruction downstream the bulb will get sucked shut and you will run out of fuel. They work great on 2-strokes with their super low pressure fuel systems, however even there they can cause issues. I don't think it would work well long term but it would be a neat experiment. If you put a T in a the fuel line with shut-offs, a second fuel line going to your tank it would work.
If you've ever installed an electric fuel pump you will never go back. I put one on every carbed car I own. All I do is put the key in the run position, leave it there for 5 seconds or so while the fuel pump refills the bowls, pump the carb and start like normal. Even after sitting 6 months they fire up like nothing. A buddy of mine liked mine so much he put one on his school bus-camper that always used to take years of cranking now fires up easy. Other than a resto project I wouldn't mess with a mechanical fuel pump again.
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2456674
02/24/18 02:38 PM
02/24/18 02:38 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
As a multiple boat owner I can tell you that you don't want a primer bulb under the hood on an automobile...First off I don't think the fire hazzard condition outweighs the benefits...Secondly, the bulbs get hard,brittle and get hairline cracks which usually with them being far away from a marine engine isn't as crucial...There's absolutely no heat where these are mounted in a marine environment.... Those bulbs are for 2 cycle,contained engines{outboards} not an inboard,mounted fuel tank v8..These are suction/gravity systems with no pressure the bulb isn't designed for any pressure application....
It's easy enough to add fuel to the carb using the methods already outlined...Although the bulb looks to be an easy way out it's just too risky and seriously misapplied in an automobile...And I guarantee you it won't pass inspection with it anywhere on the car..
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2456681
02/24/18 02:46 PM
02/24/18 02:46 PM
St. Louis
I
Imrare Offline
Imrare  Offline
I
St. Louis
The cranking involved in priming a carburetor that has been sitting for a spell has the added benefit of making sure everything is well oiled (by your oil pump) when the engine does spring to life. Nothing worse than "zinging" an engine with a "dry" top end.
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2456705
02/24/18 03:22 PM
02/24/18 03:22 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I would check the rubber hoses for cracks, the clamps for tightness and the condition of the fuel pump. I don`t think it should have to crank too long without starting. I never had any issues on cars that sat for a month or so.
Re: fuel priming bulb for car that sits often? [Re: Imrare] #2456713
02/24/18 03:33 PM
02/24/18 03:33 PM
I'm thinking you are incorrect on cranking a BB Mopar with no oil pressure while filling the fuel bowls up tsk
This is one of the old SB Chevy racers myths, it is way better to have the motor stat immediately to spin the oil pump fast enough, above starter revolution speed, to have the motor running fast enough(above 500 RPM) to make oil pressure right away up
Mopars V8, all of the older ones, oil the top end through the cam shaft so you need twice as many revolutions on the camshaft, compared to the crankshaft, to get oil to the rocker arm shafts work scope
Do NOT grind on the starter to fill the fuel bowl after a car sits for more than three or four weeks due to the awful pump swill that evaporates and goes bad in less than a month puke work
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2458180
02/26/18 11:51 PM
02/26/18 11:51 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Electric Fuel pump...git 'er done! Anyone running a carter avs knows if it sits a while the bowls dry right out. Takes 10 cranks or so to get enough fuel into the carb if the car sits more than a few days, especially with today's alcohol-laced swill...
Re: fuel priming bulb for car that sits often? [Re: Sixpak] #2458194
02/27/18 12:11 AM
02/27/18 12:11 AM
IN
ahy Offline
ahy  Offline
IN
The two carb vehicles I run got electric fuel pumps. Much faster starts after sitting, much faster hot starts after heat soak and vapor lock issues on hot days/heavy load eliminated.
PS: first is to get the fuel system, fuel lines, pump ect. in good shape. The electric pump comes after making sure the system is solid.
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2458196
02/27/18 12:15 AM
02/27/18 12:15 AM
BlueRacer69 Offline
BlueRacer69  Offline
I have the same issue with my car if it sits for 3 or 4 weeks. All the gas evaporates from the carbs fuel bowls. I just pour a little gas in the carb and it starts right up.
Re: fuel priming bulb for car that sits often? [Re: Alaskan_TA] #2458261
02/27/18 08:32 AM
02/27/18 08:32 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
That's what I use.
Cheap and simple.
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2458586
02/27/18 09:49 PM
02/27/18 09:49 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Snow blowers have a primer bulb that pushes air pressure in to an almost sealed carb very small vent hole,the air pushes fuel up through the jets & wets the carb.Now on a similar note take a windshield washer foot pump plumbed into an almost sealed plastic container again with a very small vent hole with two ports on it with one having a dip tube,mount the container in front of the rad support away from direct heat plumb with vacuum hose from foot pump to canister short port,plumb from canister port with dip tube to air filter using a partial vacuum hose to a small steel line that would squirt into the air filter some how,the principles the same & I suppose it could work build at your own risk.
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2459688
03/02/18 12:17 AM
03/02/18 12:17 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The root of the problem is the Edelbrock carb. They, like the Carter AFB feed the pump shot cylinder from the top of the bowl. So any evaporation and you have no pump shot. It also requires a lot of cranking to completely fill the bowl so you can finally have pump shot.
At least a Holley feed the pump shot from the bottom of the bowl. So even with 90% of the fuel from the bowl evaporated, you will still have pump shot. Which is what ALL of these car need to fire up on a cold start.
Re: fuel priming bulb for car that sits often? [Re: Alaskan_TA] #2459991
03/02/18 05:03 PM
03/02/18 05:03 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
This is basically what I do.
Nothing fancy needed.
I have a couple old trucks that go dry if sitting for any length of time. This always get 'em to fire up.
I have mechanical Aptitude.
I can screw up anything.
