small rivets for gauges.. where to find them? #2454873
02/21/18 12:28 AM
02/21/18 12:28 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
working on a vintage 69 mopar gauge set.. need the little flat black rivets that hold the gauges to the tin backing.. any ideas?
Re: small rivets for gauges.. where to find them? [Re: ph23vo] #2454888
02/21/18 01:08 AM
02/21/18 01:08 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Premiumdashdecals.com in Ontario sell them
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: small rivets for gauges.. where to find them? [Re: ph23vo] #2455340
02/21/18 11:14 PM
02/21/18 11:14 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Tubular rivets are available from Hanson Rivet.
http://www.hansonrivet.com/
or you could use a brass solid AN aircraft rivets.
If the rivet is not seen when the bezel is install, really any rivet will do.
Re: small rivets for gauges.. where to find them? [Re: ph23vo] #2455402
02/22/18 01:34 AM
02/22/18 01:34 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Inquiring minds want to know Dan. wave
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: small rivets for gauges.. where to find them? [Re: BloFish] #2456156
02/23/18 02:41 PM
02/23/18 02:41 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
hey steve! hope all is well with you and the family..working on a c body oil gauge [maybe].. no real progress on my projects lately..but will know where things are headed in a few months with my moms health challenges.. may be moving her or going back to seattle to take care of her..time will tell...
