Re: small rivets for gauges.. where to find them?
[Re: ph23vo]
#2455340
02/21/18 11:14 PM
02/21/18 11:14 PM
Posts: 709 St Louis, MO 63026
convx4
St Louis, MO 63026
Tubular rivets are available from Hanson Rivet. http://www.hansonrivet.com/ or you could use a brass solid AN aircraft rivets. If the rivet is not seen when the bezel is install, really any rivet will do.
[Re: ph23vo]
#2455402
02/22/18 01:34 AM
02/22/18 01:34 AM
Posts: 16,471 On the run…
BloFish
On the run…
working on a vintage 69 mopar gauge set.. need the little flat black rivets that hold the gauges to the tin backing.. any ideas? Inquiring minds want to know Dan.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
