Page 2 of 3 1 2 3
Re: who runs torque straps, limiters? [Re: OhioMopar] #2454971
02/21/18 05:38 AM
02/21/18 05:38 AM
One of my local street driver show car customers removed them after trying them in his 1963 Sport Fury Max wedge car shruggy He didn't like the vibrations shruggy
He is a little picky on a lot of things though whistling shruggy
Re: who runs torque straps, limiters? [Re: OhioMopar] #2454974
02/21/18 06:48 AM
02/21/18 06:48 AM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
Originally Posted By OhioMopar
Has anyone used the Shumacher Poly-Locs?
Had them for several years .
The one on right hand side did collapse , drivers side been fine . Just fitted a stock one to r/h side . No dramas since
Have thought about going solid on driver side only
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: who runs torque straps, limiters? [Re: superchuck] #2454982
02/21/18 09:02 AM
02/21/18 09:02 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Call me a hillbilly, but a 1” wide polyester ratchet strap will hold close to 4000 pounds of force, wont transfer vibration, is easily installed/ removed, and costs about $8.00.
I’m only guessing here, but I would assume that your engine makes under 500 lb/ft. Using 500 lb/ft as a base number, anything that will hold 500 lbs of force mounted 1 foot from the crankshaft centerline will do the job. Worrying about headbolt shear is a non issue. You could quite literally lift your entire car from one cylinder head with no ill effects(to the engine) with ease.
As far as block damage at the factory mount... It is very common to see the corners of the engine mounting bosses cracked off. This is a poorly designed and machined area from the factory. But it is almost always seen on the passenger side. The engine in my car was mounted by the factory mount bosses( broken pass side when I got it ) and it made over 900 lb/ft of torque. The car weight was 3700 lbs, had a 3.50 rear gear and ran high 8 sec 1/4s. Never had any issue with engine mounting.
Re: who runs torque straps, limiters? [Re: superchuck] #2454985
02/21/18 09:16 AM
02/21/18 09:16 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Year of experience using engine stabilizers or torque straps dictates the use of 2 stabilizers, one on each side. There is nothing better than the schumaker design and the design works well. This set up does not transmit excess vibration to the car.
The old school thought of a right side solid mount and a left side regular mount is still old school and is a band-aid solution. The Schumaker design adapts very easily to the right side.
By only stabilizing one side an excessive amount of force is now applied against the right side motor mount. This compression on the right side mount the mount causes the drive line to twist in place and pushes the right side collector down and eventually tears the right rear muffler hanger. The mount will eventually fail. Using the high quality mounts available like mity mounts helps but they are not a substitute for 2 stabilizers. As this is the internet...and of course since i won't post a pic of said type failure I have no clue what i am talking about....
drive
Re: who runs torque straps, limiters? [Re: ThermoQuad] #2455028
02/21/18 12:02 PM
02/21/18 12:02 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
A whole year?
wave Just kidding.
Master, again and still
Re: who runs torque straps, limiters? [Re: superchuck] #2455419
02/22/18 02:14 AM
02/22/18 02:14 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Schumacher strap made my 4 speed shift way easier and I noticed very little increase in vibrations.
I want my fair share
Re: who runs torque straps, limiters? [Re: ThermoQuad] #2455424
02/22/18 02:27 AM
02/22/18 02:27 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
drive
I don’t doubt your point about the Schumacher system to be completely valid, and I’m going to stop short of saying you don’t have a clue; but....... I’ve been running the system you say causes all kinds of problems for 8 years, car gets raced regularly, has a full exhaust system with tailpipes and muffler hangers..... I’ve never seen one of the problems you mention. Same motor mounts and exhaust system for 8 years.
shruggy
Re: who runs torque straps, limiters? [Re: StealthWedge67] #2455441
02/22/18 03:06 AM
02/22/18 03:06 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I ran the poly lock mounts for a few years with a Schumacher torque strap.
Over time the mounts sheared. The right side mount was real ugly. The engine would twist on the mounts, not lift on the left side.
I found this after my reaction times became erratic, and the drivers side header became the limiter.
I am not bashing the product. They lasted 500 or so passes on my smallblock.
"Just a Bracket car dressed up like a streetcar"
Re: who runs torque straps, limiters? [Re: Just-a-dart] #2455645
02/22/18 03:13 PM
02/22/18 03:13 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I use what were sold as "Mighty Mounts" IIRC on both sides, along with a Competition Engineering torque strap they sell for 5.0 'stangs. It's not a bolt-on, but didn't take that much modification to work on my E-body. See link HERE.
I set up the strap with just a bit of free play to keep the vibration transfer down, but it "locks up" as soon as the engine tries to torque over. Works for me...
Re: who runs torque straps, limiters? [Re: BradH] #2455705
02/22/18 05:00 PM
02/22/18 05:00 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Thanks Brad, I just ordered one.
Re: who runs torque straps, limiters? [Re: Jeremiah] #2456149
02/23/18 02:35 PM
02/23/18 02:35 PM
BradH Offline
BradH  Offline
If I remember, I'll take some pics of how I modified & mounted it. It's bolted to the k-member and attached to the top hole of the front engine mount, since I didn't want to take a chance w/ it distorting the cylinder head if I'd mounted it on the accessory bolt holes. The nice thing is it's RIGID only under load w/o the constant engine vibration I felt through the car when using only a single solid mount on the driver's side.
Re: who runs torque straps, limiters? [Re: BradH] #2456244
02/23/18 05:15 PM
02/23/18 05:15 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Much appreciated. I actually ordered two in case I can used one as a fore-aft limiter.
Re: who runs torque straps, limiters? [Re: superchuck] #2456488
02/24/18 02:14 AM
02/24/18 02:14 AM
Sydney,Australia
Sydney,Australia
Ok
Pulled my oil pan today , cracked on weld . Also shows sign of driver mount given up and pan hitting steeting box support
Who has seen a damaged block from solid driver side mount . I do use a transbrake . Vibration dont care
Tex
New best MPH 130.32
Re: who runs torque straps, limiters? [Re: superchuck] #2456562
02/24/18 09:51 AM
02/24/18 09:51 AM
ThermoQuad Offline
ThermoQuad  Offline
My suggestion that you need 2 torque limiters is from a data collection of 24+ years running high speed road course laps [130mph+], 4 days per year, 140 laps per year, 2.5 min per lap. 2.5 min is very respectable. How many 1/4 mile passes does that equal? scope
140 x 24 = 3360 laps x 2.47 miles per lap = 8,300 miles x 4 = 33,197 1/4 mile passes. cool eek grin
2 cars, 1 small block, one big block - same problem - compressed right side mount; right side TTI header collector pointing down under large throttle load, right side muffler straps at the muffler tear, the motor is not level side to side at rest.
Please note the right side collector in the attached picture for photographic evidence of the phenomena. scope
Maybe now the picture and math will help make sense of why 2 torque limiting devices are required not a luxury.
These devices cannot be a rigid mount, there has to be a degree of give to isolate the engine vibration. I promise never to come over here into your playground again.
panic
Re: who runs torque straps, limiters? [Re: superchuck] #2457756
02/26/18 07:04 AM
02/26/18 07:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have been running a solid mount on just the drivers side for about 8 years. I had this chain for backup when I ran a stock mount so I leave it on for backup in case the solid mount would break a weld. But I don't run the car hard on the street and only race it once or twice a year. I have never had any problems from running a solid mount on the drivers side. Ron
Re: who runs torque straps, limiters? [Re: superchuck] #2457757
02/26/18 07:22 AM
02/26/18 07:22 AM
Sydney,Australia
Sydney,Australia
https://www.alllifting.com.au/wp-content...ottle-screw.jpg
I just bought similar to this , make a coupke small brackets to connect motor mount bolt to k frame
Tex
New best MPH 130.32
Re: who runs torque straps, limiters? [Re: tex013] #2490191
04/30/18 11:50 PM
04/30/18 11:50 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
As mentioned in my above thread, I installed the Schumaker limiter to the drivers side over the Winter and I just got back from my first test drive. I used to have a steering wheel vibration at idle in D, and my hood used to shake at highway speeds. Both issues are now gone. But I am now wondering if I had a bad mount even though both looked to be in good visual shape.
No additional vibrations with this install.
Re: who runs torque straps, limiters? [Re: superchuck] #2490199
05/01/18 12:05 AM
05/01/18 12:05 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
After running it for a number of years without, we put fore/aft limiters on our car with a small block on motor plates. Not big power, not real fast. It would go mid 1.20s in 60, but it was light. That was eye opening. Won't run one like that again without them.
Re: who runs torque straps, limiters? [Re: srunge55] #2490397
05/01/18 12:57 PM
05/01/18 12:57 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Originally Posted By srunge55
I'm trying to figure out the best way to do this also. I have heard of some guys using a solid MM on the drivers side and a stock rubber on the passenger side.
I have also heard of using a regular MM but drilling and running a bolt through it. I think Mancini sells something called a mega mount which looks like the same thing. Seems like a simple cheap thing to do yourself but I haven't tried it yet.
Thanks,
Steve
This is what I did on my driver's side MM and the passenger side was left stock rubber.
Re: who runs torque straps, limiters? [Re: superchuck] #2490601
05/01/18 07:06 PM
05/01/18 07:06 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Solid motor mounts here. Tried straps and turn buckels over the years. Got to the point that the driver side would not break, but the passenger side would. Got tired of dealing with it and went solid(both sides). I deal with the minor vibrations and after several years, it don't bother me much anymore. Rock solid when I hit the gears. NO flex or movement at all.. My car is a stick car. Auto's may have a different reaction
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Page 2 of 3 1 2 3
