Big block 3x2 intakes #2455273
02/21/18 08:51 PM
02/21/18 08:51 PM
ohio
ruderunner Offline OP
ohio
What options are out there besides the original SixPack stuff, the repop stuff and the B engine manifold from Edelbrock?
I thought Offenhouser made one long ago, anyone else?
Angry white pureblood male
Re: Big block 3x2 intakes [Re: ruderunner] #2455275
02/21/18 08:54 PM
02/21/18 08:54 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
A lot of offy stuff is still available direct from them.
Re: Big block 3x2 intakes [Re: ruderunner] #2455319
02/21/18 10:33 PM
02/21/18 10:33 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The Edelbrock is the best.
Re: Big block 3x2 intakes [Re: ruderunner] #2455323
02/21/18 10:38 PM
02/21/18 10:38 PM
ohio
ohio
I should have been clearer, I'm looking for used stuff. Hey I got a family to support. Just wondering what to look for.
Re: Big block 3x2 intakes [Re: ruderunner] #2455333
02/21/18 11:00 PM
02/21/18 11:00 PM
Do you want looks or performance?
Re: Big block 3x2 intakes [Re: ruderunner] #2455343
02/21/18 11:19 PM
02/21/18 11:19 PM
Alabama
BigMoneyLewis Offline
Alabama
It's going to be somewhat expensive, no matter which route you go.
Probably your best bet is a good used Edelbrock aluminum , or original cast iron intake, both very easily available at swap meets and e-bay .
Most expensive route would be the Edelbrock STR 14 with 3 x 2 top plate .
As far as the Offenhauser, the only ones I am familiar with are set up for
either strombergs or webbers ?
Greg
gregward@mchsi.com phone 256-852-0955
Re: Big block 3x2 intakes [Re: BigMoneyLewis] #2455352
02/21/18 11:28 PM
02/21/18 11:28 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Greg
This Offy intake looks like it has a Holley carb bolt pattern. shruggy
Then, how about 3 Rochester carburetors?
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Big block 3x2 intakes [Re: hemi71x] #2455380
02/22/18 12:25 AM
02/22/18 12:25 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Carb bolt pattern looks wrong.
Re: Big block 3x2 intakes [Re: buildanother] #2455391
02/22/18 01:05 AM
02/22/18 01:05 AM
hemi71x Offline
hemi71x  Offline
Dunno. shruggy
But this one for sure, is for Stromberg's.
Re: Big block 3x2 intakes [Re: hemi71x] #2455416
02/22/18 02:02 AM
02/22/18 02:02 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Greg
Bolt pattern way off.
Re: Big block 3x2 intakes [Re: hemi71x] #2455421
02/22/18 02:24 AM
02/22/18 02:24 AM
Dunno. shruggy
OP, both of these Offy intakes are awful performers down
The open plenum 360 designs ruin the low speed throttle response on these intakes as well as all the single four barrel and dual four barrel intakes Offy made down
The old and older two barrel carbs they where design for aren't worth using in todays world twocents work
the three bolt are for the early, pre 1958, Stromberg Carlson and older Holley two barrels, the four bolt patter is for the early low CFM flowing Rochester GM two barrel carbs, the later bigger ones where a liitle bit better but no where as good as the later Holley 2300 type two barrel carbs use on both Mopar 440 and Chevy 427 Corvettes starting in 1967 and the earlier 390 and 406 Fords back in 1961,1962 and 1963 scope thumbs
Re: Big block 3x2 intakes [Re: ruderunner] #2455454
02/22/18 03:33 AM
02/22/18 03:33 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Weiand Super Stock 6Pak tunnel ram.
Kevin
Re: Big block 3x2 intakes [Re: Twostick] #2455493
02/22/18 07:50 AM
02/22/18 07:50 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I have and have used all 3 styles.
Sadly the production Edelbrock works the best.
On a street driven car,no contest. Edelbrock
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Big block 3x2 intakes [Re: ruderunner] #2455496
02/22/18 08:22 AM
02/22/18 08:22 AM
ohio
ohio
Ok, guess I'll keep looking for an Edelbrock
Re: Big block 3x2 intakes [Re: ruderunner] #2455642
02/22/18 03:07 PM
02/22/18 03:07 PM
Smart choice up You will not regret this twocents
Re: Big block 3x2 intakes [Re: ruderunner] #2455650
02/22/18 03:22 PM
02/22/18 03:22 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The offy intake might do ok on a bone stock engine with stock heads and cam. Even if that was true they're not cheap enough to be worth messing with.
Never heard anything particularly good about the eddy STR intake with the 6bbl top plate. They are too expensive to gamble on IMO.
The high rise weiand 6-pack tunnel rams, from what I've read sound like they are a great intake. Not cheap either and fitment or non-stock appearance is an issue for some.
The edelbrock stock type 6-packs seem to do well even into the 550hp range.
Re: Big block 3x2 intakes [Re: ruderunner] #2455670
02/22/18 03:57 PM
02/22/18 03:57 PM
Chicago
PurpleBeeper Offline
Chicago
I agree with bigmoney.... the cheapest will be an aftermarket Edelbrock aluminum which cost about $410 new...maybe cheaper if you can find a used one.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
