Big block 3x2 intakes
#2455273
02/21/18 08:51 PM
02/21/18 08:51 PM
Posts: 5,754 ohio
ruderunner
ohio
What options are out there besides the original SixPack stuff, the repop stuff and the B engine manifold from Edelbrock?
I thought Offenhouser made one long ago, anyone else?
Angry white pureblood male
Re: Big block 3x2 intakes
[Re: ruderunner]
#2455323
02/21/18 10:38 PM
02/21/18 10:38 PM
Posts: 5,754 ohio
ruderunner
ohio
I should have been clearer, I'm looking for used stuff. Hey I got a family to support. Just wondering what to look for.
[Re: ruderunner]
#2455333
02/21/18 11:00 PM
02/21/18 11:00 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
Do you want looks or performance?
[Re: BigMoneyLewis]
#2455352
02/21/18 11:28 PM
02/21/18 11:28 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
It's going to be somewhat expensive, no matter which route you go. Probably your best bet is a good used Edelbrock aluminum , or original cast iron intake, both very easily available at swap meets and e-bay . Most expensive route would be the Edelbrock STR 14 with 3 x 2 top plate . As far as the Offenhauser, the only ones I am familiar with are set up for either strombergs or webbers ?
Greg This Offy intake looks like it has a Holley carb bolt pattern. Then, how about 3 Rochester carburetors?
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: hemi71x]
#2455416
02/22/18 02:02 AM
02/22/18 02:02 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Greg This Offy intake looks like it has a Holley carb bolt pattern. Then, how about 3 Rochester carburetors? Bolt pattern way off.
[Re: hemi71x]
#2455421
02/22/18 02:24 AM
02/22/18 02:24 AM
Cab_Burge
Carb bolt pattern looks wrong. Dunno. But this one for sure, is for Stromberg's. OP, both of these Offy intakes are awful performers The open plenum 360 designs ruin the low speed throttle response on these intakes as well as all the single four barrel and dual four barrel intakes Offy made The old and older two barrel carbs they where design for aren't worth using in todays world the three bolt are for the early, pre 1958, Stromberg Carlson and older Holley two barrels, the four bolt patter is for the early low CFM flowing Rochester GM two barrel carbs, the later bigger ones where a liitle bit better but no where as good as the later Holley 2300 type two barrel carbs use on both Mopar 440 and Chevy 427 Corvettes starting in 1967 and the earlier 390 and 406 Fords back in 1961,1962 and 1963
[Re: Twostick]
#2455493
02/22/18 07:50 AM
02/22/18 07:50 AM
Posts: 3,830 N.E. Ohio
6bblFLASH
N.E. Ohio
I have and have used all 3 styles. Sadly the production Edelbrock works the best. On a street driven car,no contest. Edelbrock
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: ruderunner]
#2455496
02/22/18 08:22 AM
02/22/18 08:22 AM
Posts: 5,754 ohio
ruderunner
ohio
Ok, guess I'll keep looking for an Edelbrock
[Re: ruderunner]
#2455642
02/22/18 03:07 PM
02/22/18 03:07 PM
Cab_Burge
Ok, guess I'll keep looking for an Edelbrock Smart choice You will not regret this
[Re: ruderunner]
#2455670
02/22/18 03:57 PM
02/22/18 03:57 PM
Posts: 953 Chicago
PurpleBeeper
Chicago
I agree with bigmoney.... the cheapest will be an aftermarket Edelbrock aluminum which cost about $410 new...maybe cheaper if you can find a used one.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
