MSD distributor timing curves #2454455
02/20/18 11:04 AM
02/20/18 11:04 AM
Easton, PA
68DART360 Offline OP
Easton, PA
Reading the instructions on setting an advance curve for my 360, I'm at a loss with so many combos. Anybody using one that works best? My motor is a 10 to 1 360 with edelbrock heads. Drag race car only. I use a mixture of 110 and 93 pump gas. about 4 to 1 gallon ratio. Do I just pick one and test and tune the car to see what it likes? Just looking for a good baseline.
Re: MSD distributor timing curves [Re: 68DART360] #2454462
02/20/18 11:25 AM
02/20/18 11:25 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
When i had a pump gas 408 in the car i used the silver and the lite blue spring together. Think the initial timing was about 20*. Depending on how big your cam is, you may be able to just lock out the timing. I tried both ways and couldn't tell much difference. If your cam is 270*@50 or larger on intake, I would just lock it out 34*-36* should work fine. You may need a start retard when locked out.
Re: MSD distributor timing curves [Re: 68DART360] #2454517
02/20/18 01:08 PM
02/20/18 01:08 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
What I found was the bushings all allowed to much advance for the initial that my engine needed. My engine ran best with 34° total and liked 22° initial. If I set the total timing it wasn't happy at idle and if I set it at idle it had way to much total.
There was a member here that made custom bushings so I bought one and sanded it down to get the right amount of advance. It's been years ago and I can't remember who it was.
Re: MSD distributor timing curves [Re: 68DART360] #2454522
02/20/18 01:16 PM
02/20/18 01:16 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Locking out the distributor will make your car run more consistent.
Re: MSD distributor timing curves [Re: justinp61] #2454532
02/20/18 01:34 PM
02/20/18 01:34 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yur right and just reminded me i had to get the larger bushings thru FBO. With the larger bushing and the lite silver and blue springs a this curve works good. But again, if your cam is large giving low idle vacuum, locked out is best with a start retard.
Re: MSD distributor timing curves [Re: A/MP] #2454535
02/20/18 01:38 PM
02/20/18 01:38 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I agree and probably will make it 60 foot faster
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: MSD distributor timing curves [Re: WHITEDART] #2454552
02/20/18 02:22 PM
02/20/18 02:22 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have my 511 locked out. With any kind of significant cam over lap its best to just lockem out. My car is mostly street and i get better street manners with it locked out.
Re: MSD distributor timing curves [Re: justinp61] #2454557
02/20/18 02:34 PM
02/20/18 02:34 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
Crackedback is who you're looking for. I bought a 10* bushing from him. Works great for my 22 initial and 32 total on the 472 hemi... Or at least I'm somewhat sure that's what his name is?!?!?!?!?!
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: MSD distributor timing curves [Re: MoparJunkie] #2454569
02/20/18 02:45 PM
02/20/18 02:45 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I believe you're correct.
Re: MSD distributor timing curves [Re: 68DART360] #2454573
02/20/18 03:01 PM
02/20/18 03:01 PM
Gravataí, RS, Brazil
360tripleblack77 Offline
I'm running with 24° initial and 36° total timing. 12.0:1 CR, Eddy Heads, 95 octane pump gas and 30% of ethanol.
When I ran on dyno, engine loved 26° initial and 38° total timing But last time that I ran at Track was very hot and I just keep 24° and 36°.
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: MSD distributor timing curves [Re: A/MP] #2454581
02/20/18 03:19 PM
02/20/18 03:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yep, beer
Re: MSD distributor timing curves [Re: 68DART360] #2454616
02/20/18 03:55 PM
02/20/18 03:55 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Don at 4secondsflat (FBO) stocks them if you decided to go that route.
Re: MSD distributor timing curves [Re: 68DART360] #2454621
02/20/18 04:01 PM
02/20/18 04:01 PM
Cab_Burge Online work
Cab_Burge  Online Work
Most SB on gasoline don't need or like a lot of total advance, all the ones I've helped like 30 to 32 total. On your deal I would shoot for 14 to 18 at idle and 32 degrees total (make sure and test at 30 to 36 in two degrees increments due to the difference in timing marks on the balancer and timing covers and the differences in timing lights used on MSD ignitions to find out what your numbers need to be to run the fastest with your car scope) above 1500 RPM twocents
Good luck, let us know later what yours works the best with thumbs
Re: MSD distributor timing curves [Re: 68DART360] #2454627
02/20/18 04:07 PM
02/20/18 04:07 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I've fooled around making bushings and fooling around with curves on street driven stuff. Anything with a decent cam and converter, lock it out. Or just put a crank trigger on it. If you really need or want to control a timing curve, do it electronically.
Re: MSD distributor timing curves [Re: 68DART360] #2454632
02/20/18 04:16 PM
02/20/18 04:16 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Just make sure all the timing is in by 3,000rpm and check it at 3,000rpm or above. I wouldn't run more than about 34 total.
Re: MSD distributor timing curves [Re: 68DART360] #2454640
02/20/18 04:38 PM
02/20/18 04:38 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
back in the day it was trial and error, now I use performance trend engine analizer software, it calculates an advace curve for what ever octane fuel you want to run. Like most programs garbage in garbage out, but if you take the time to be accurate with the info it works good. I just did a procharged 410 mopar with a fitech, calculted the advance curve with and with out boost imputed the numbers into the Fitech computer as a starting point for the ignition advance, it ran great. I am running 6 lbs of boost on pump gas. When I decide to change pulleys and good gas, will calculate again and see what happens.
Re: MSD distributor timing curves [Re: Dave Hall] #2454650
02/20/18 05:02 PM
02/20/18 05:02 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Right. With light springs, it's in by 12-1500. My reasoning is most engines - that aren't bone stock - are above 3k before they move off the spot. Why not just lock it out, and take advantage of the improved and stable idle, throttle response and carb function? I'm talking carburated drag racing.
Re: MSD distributor timing curves [Re: 68DART360] #2454657
02/20/18 05:10 PM
02/20/18 05:10 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
For the guys running 34-36° timing locked out are there any hot start issues? My car is a street/strip and I don't want to have to deal with hard hot starts.
Re: MSD distributor timing curves [Re: justinp61] #2454663
02/20/18 05:15 PM
02/20/18 05:15 PM
Washington
madscientist Offline
Washington
What ignition are you running? Most of them have some kind of start retard, and most of them you can adjust the amount of retard.
Re: MSD distributor timing curves [Re: 68DART360] #2454665
02/20/18 05:20 PM
02/20/18 05:20 PM
CA
crackedback Offline
crackedback  Offline
CA
Yep, I have the bushings in 10 and 14 degree sizes.
$10 each plus shipping
Thanks 70HemiShaker. Glad it worked as advertised for you.
IMO, let the engine tell you what it wants for idle timing. Even stock 340's like 14-16 which is way more than most people think considering the factory started at 10 and dialed it back later for emissions.
Simple test, get it warmed up and idling, twist the dist a smidge CCW, if it picked up RPM, the engine wants the timing. Reset idle speed and do it again. You'll find the happy place. It may not want to start with the point it's happiest, bit of a balancing act. Won't start dial it back to where it will when hot.
Locking it out is another consideration, make sure you have good battery cables... smile
