Guess my Dyno numbers
#2454415
02/20/18 04:50 AM
02/20/18 04:50 AM
Posts: 1,278 Mission BC
10sec440
Mission BC
511 low deck, Indy 440-1's unported but bowl blended and port matched. Comp flat tappet intake Duration @.050: 265 Camshaft - Exhaust Duration @.050: 270 Camshaft - Intake Lift at Valve: 585 Camshaft - Exhaust Lift at Valve: 592 Lobe Separation: 110 10.5 compression pump gas Indy 4500 manifold and 1050 carb. Bob Mazz 2" 2-1/8" step headers Hope to be on the dyno this weekend.
Re: Guess my Dyno numbers
[Re: 10sec440]
#2454575
02/20/18 03:08 PM
02/20/18 03:08 PM
Posts: 860 lancaster,california
johnnycuda
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: 10sec440]
#2454582
02/20/18 03:22 PM
02/20/18 03:22 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
745hp 640tq, just saw one come off the dyno it made 20 hp more with vac. pump....
Have a great day Iowan
"obsolete is neat"
[Re: 10sec440]
#2454590
02/20/18 03:30 PM
02/20/18 03:30 PM
Posts: 566 Texas
RustyM
Texas
655 hp, 690 tq
how far are you going to turn it?
[Re: krautrock]
#2454591
02/20/18 03:32 PM
02/20/18 03:32 PM
Posts: 289 Lowes
steve660
Lowes
According to Wallace racing calculator, 3400lbs @ 130 MPH is 575hp....
Sorry, didnt notice the "440" in signature..
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: 10sec440]
#2454898
02/21/18 01:17 AM
02/21/18 01:17 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
I'll be really surprised if it doesn't make north of 650 HP and 620 Ft lb. of torque with those parts What brand engine dyno and how much elevation, humidity and barometric pressure on the dyno are you expecting Good luck
[Re: CSK]
#2454932
02/21/18 03:01 AM
02/21/18 03:01 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Geez, your talking rear wheel yeah ? Im at 600 RWHP with ported SR's, surely this combo should be high 600's + at the flywheel ? 680 FWHP
1963 Plymouth Max Wedge 1971 Barracuda
[Re: 10sec440]
#2455038
02/21/18 12:41 PM
02/21/18 12:41 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Whose dyno?? On a few dynos quoted on here, I'm sure it would show over 800...
I'll wager...132 to 133 mph
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
