Page 1 of 5 1 2 3 4 5
Guess my Dyno numbers #2454415
02/20/18 04:50 AM
02/20/18 04:50 AM
Mission BC
10sec440 Offline OP
10sec440  Offline OP
Mission BC
511 low deck, Indy 440-1's unported but bowl blended and port matched. Comp flat tappet intake Duration @.050: 265
Camshaft - Exhaust Duration @.050: 270
Camshaft - Intake Lift at Valve: 585
Camshaft - Exhaust Lift at Valve: 592
Lobe Separation: 110
10.5 compression pump gas
Indy 4500 manifold and 1050 carb.
Bob Mazz 2" 2-1/8" step headers
Hope to be on the dyno this weekend.
Re: Guess my Dyno numbers [Re: 10sec440] #2454420
02/20/18 05:06 AM
02/20/18 05:06 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
725HP---625 TQ
Re: Guess my Dyno numbers [Re: qwkmopardan] #2454574
02/20/18 03:04 PM
02/20/18 03:04 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
690 hp / 595 tq
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Guess my Dyno numbers [Re: 10sec440] #2454575
02/20/18 03:08 PM
02/20/18 03:08 PM
lancaster,california
johnnycuda Online content
johnnycuda  Online Content
675hp / 560tq
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Guess my Dyno numbers [Re: 10sec440] #2454576
02/20/18 03:09 PM
02/20/18 03:09 PM
Renton Washington
Triple Threat Offline
Renton Washington
Not enough smile
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Guess my Dyno numbers [Re: 10sec440] #2454582
02/20/18 03:22 PM
02/20/18 03:22 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
745hp 640tq, just saw one come off the dyno it made 20 hp more with vac. pump....
Have a great day
Iowan
"obsolete is neat"
Re: Guess my Dyno numbers [Re: 10sec440] #2454585
02/20/18 03:24 PM
02/20/18 03:24 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
are those cam specs correct? 294 and 305* @ .050" and only 585 lift??
Re: Guess my Dyno numbers [Re: 10sec440] #2454590
02/20/18 03:30 PM
02/20/18 03:30 PM
Texas
RustyM Offline
RustyM  Offline
Texas
655 hp, 690 tq
how far are you going to turn it?
Re: Guess my Dyno numbers [Re: krautrock] #2454591
02/20/18 03:32 PM
02/20/18 03:32 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
According to Wallace racing calculator, 3400lbs @ 130 MPH is 575hp....
Sorry, didnt notice the "440" in signature..
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Guess my Dyno numbers [Re: krautrock] #2454607
02/20/18 03:50 PM
02/20/18 03:50 PM
gregsdart Offline
gregsdart  Offline
my thoughts also. I am thinking those must be at .020, or .006, which will alter the results a bit😀
Re: Guess my Dyno numbers [Re: 10sec440] #2454723
02/20/18 07:14 PM
02/20/18 07:14 PM
Canada
RobR Offline
RobR  Offline
Canada
Cam specs are wrong for the lift..I'd guess something like 275@50 would be more in line..IMO
Re: Guess my Dyno numbers [Re: 10sec440] #2454724
02/20/18 07:18 PM
02/20/18 07:18 PM
Mission BC
10sec440 Offline OP
10sec440  Offline OP
Mission BC
Sorry, typo it was late. 265 and 270 @ .050
I intend to spin it to 6500-7000.
Thanks.
Re: Guess my Dyno numbers [Re: 10sec440] #2454827
02/20/18 10:59 PM
02/20/18 10:59 PM
AndyF Offline
AndyF  Offline
Probably around 625 hp with those parts. Could easily be more with proper head work, ported intake and a roller cam. You have another 100 hp of potential in that basic combo.
Re: Guess my Dyno numbers [Re: 10sec440] #2454862
02/20/18 11:56 PM
02/20/18 11:56 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Unported heads, I would guess 620 hp and about the same in torque. Like Andy said at least 100hp potential with roller cam plus head and intake porting.
Re: Guess my Dyno numbers [Re: 10sec440] #2454892
02/21/18 01:13 AM
02/21/18 01:13 AM
Mission BC
10sec440 Offline OP
10sec440  Offline OP
Mission BC
That was part of my plan, make 620-650 now and then step it up at a later date.
Re: Guess my Dyno numbers [Re: 10sec440] #2454898
02/21/18 01:17 AM
02/21/18 01:17 AM
I'll be really surprised if it doesn't make north of 650 HP and 620 Ft lb. of torque with those parts twocents
What brand engine dyno and how much elevation, humidity and barometric pressure on the dyno are you expecting work
Good luck thumbs
Re: Guess my Dyno numbers [Re: 10sec440] #2454929
02/21/18 02:42 AM
02/21/18 02:42 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
585 hp
Re: Guess my Dyno numbers [Re: CSK] #2454932
02/21/18 03:01 AM
02/21/18 03:01 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Originally Posted By csk
585 hp
Geez, your talking rear wheel yeah ? Im at 600 RWHP with ported SR's, surely this combo should be high 600's + at the flywheel ?
680 FWHP
1963 Plymouth Max Wedge
1971 Barracuda
Re: Guess my Dyno numbers [Re: ozymaxwedge] #2454958
02/21/18 04:35 AM
02/21/18 04:35 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
My 12.9 493 with ported Edelbrock heads, .660 roller and flowed BG dom. on a Team G made right at 650 hp and torque. Peak torque was right at 5,800 so I would shift the 3 speed at 6,200 which was the quickest the car went. Shifting any higher would slow it down some. I would imagine yours should make a little less and 625 seems about right. Some guys on here go pretty quick with large, solid cams. I would just put a roller in it now if it were mine.
Re: Guess my Dyno numbers [Re: 10sec440] #2455038
02/21/18 12:41 PM
02/21/18 12:41 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Whose dyno?? On a few dynos quoted on here, I'm sure it would show over 800...
I'll wager...132 to 133 mph
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
