1st gen D100 springs #2453643
02/18/18 09:53 PM
02/18/18 09:53 PM
Atlanta, GA
mgoblue9798 Offline OP
Atlanta, GA
Has anyone found a progressive rate or cargo coil front spring for our trucks? Getting ready for a front suspension rebuilt and would like to find one to hopefully help improve the ride. Thanks in advance.
Re: 1st gen D100 springs [Re: mgoblue9798] #2454254
02/19/18 11:29 PM
02/19/18 11:29 PM
Central US
grancuda Online content
grancuda  Online Content
Central US
1st gen D100 uses leaf springs not coils. What year are you working on?
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: 1st gen D100 springs [Re: grancuda] #2454306
02/20/18 12:25 AM
02/20/18 12:25 AM
Atlanta, GA
Atlanta, GA
You overlooked the part where I asked about front springs. All D series trucks 72-93 have front coil springs.
Re: 1st gen D100 springs [Re: mgoblue9798] #2454313
02/20/18 12:39 AM
02/20/18 12:39 AM
Central US
Central US
I did see where you said front springs, also saw 1st gen which isn't 72-93.
1st generation D-series use a solid front axle with leaf springs.
2021 Toyota Supra
Re: 1st gen D100 springs [Re: grancuda] #2454335
02/20/18 01:08 AM
02/20/18 01:08 AM
Atlanta, GA
Atlanta, GA
Gotcha. Some sites call the 72-93 first gen. Anyway, it is cleared up now.
Re: 1st gen D100 springs [Re: mgoblue9798] #2454345
02/20/18 01:27 AM
02/20/18 01:27 AM
Central US
Central US
As far as I've seen you can't get progressives for the 72-93 D100
I have a few buddies here in Tulsa that use a local spring shop that use the factory spring ratings & have them build springs with progressive rates & a little shorter than stock. Not sure where you are or what shops you have local but that's an option if you don't find an aftermarket vendor for them.
2021 Toyota Supra
Re: 1st gen D100 springs [Re: grancuda] #2454416
02/20/18 04:58 AM
02/20/18 04:58 AM
Atlanta, GA
Atlanta, GA
Thank you sir. I will look into it.
Re: 1st gen D100 springs [Re: mgoblue9798] #2454515
02/20/18 01:07 PM
02/20/18 01:07 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I always check with Spring Align, they are in the Chicago area but there are shops like them all over. wave
JB Rhinehart, Realist
A-Body's RULE!
