Re: 1st gen D100 springs
[Re: mgoblue9798]
#2454254
02/19/18 11:29 PM
02/19/18 11:29 PM
Posts: 1,009 Central US
grancuda
Central US
Has anyone found a progressive rate or cargo coil front spring for our trucks? Getting ready for a front suspension rebuilt and would like to find one to hopefully help improve the ride. Thanks in advance. 1st gen D100 uses leaf springs not coils. What year are you working on?
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
[Re: grancuda]
#2454306
02/20/18 12:25 AM
02/20/18 12:25 AM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
You overlooked the part where I asked about front springs. All D series trucks 72-93 have front coil springs.
[Re: mgoblue9798]
#2454313
02/20/18 12:39 AM
02/20/18 12:39 AM
grancuda
Central US
I did see where you said front springs, also saw 1st gen which isn't 72-93.
1st generation D-series use a solid front axle with leaf springs.
[Re: mgoblue9798]
#2454345
02/20/18 01:27 AM
02/20/18 01:27 AM
grancuda
Central US
As far as I've seen you can't get progressives for the 72-93 D100
I have a few buddies here in Tulsa that use a local spring shop that use the factory spring ratings & have them build springs with progressive rates & a little shorter than stock. Not sure where you are or what shops you have local but that's an option if you don't find an aftermarket vendor for them.
[Re: mgoblue9798]
#2454515
02/20/18 01:07 PM
02/20/18 01:07 PM
Posts: 43,555 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I always check with Spring Align, they are in the Chicago area but there are shops like them all over.
JB Rhinehart, Realist
A-Body's RULE!
