Best way to clean seam sealer from drip rails #2453977
02/19/18 04:02 PM
02/19/18 04:02 PM
Guitar Jones Offline OP
I have another roof for my 1st gen club cab that was cut at the pillars about 8 inches down. I need to get the sealer out of the drip rails so I can get the roof panels separated.
This stuff is like cement in there so not wanting to use a hammer and chisel I was wondering if anyone has a better/easier way of removing the sealer.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Best way to clean seam sealer from drip rails [Re: Guitar Jones] #2453997
02/19/18 04:37 PM
02/19/18 04:37 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Propane torch.
Sheldon
Re: Best way to clean seam sealer from drip rails [Re: Guitar Jones] #2453999
02/19/18 04:41 PM
02/19/18 04:41 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Re: Best way to clean seam sealer from drip rails [Re: Guitar Jones] #2454004
02/19/18 04:50 PM
02/19/18 04:50 PM
work I have a propane torch, don't have a wire wheel though. laugh2
Re: Best way to clean seam sealer from drip rails [Re: Guitar Jones] #2454045
02/19/18 06:23 PM
02/19/18 06:23 PM
scratchnfotraction Offline
I used a couple of the green scotch-brite wheel disc in a drill and a couple wire wheels in the air die grinder.
Re: Best way to clean seam sealer from drip rails [Re: Guitar Jones] #2454073
02/19/18 07:01 PM
02/19/18 07:01 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I had a piece of 1/2 x 1/8" stock that I ground down to fit into channel. I also ground a chisel point to get up and under the material. Just tapped it with a hammer and worked it down the channel. Then cleaned up with a stiff wire wheel.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Best way to clean seam sealer from drip rails [Re: RoadRunner] #2454121
02/19/18 08:44 PM
02/19/18 08:44 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Works like a charm!
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Best way to clean seam sealer from drip rails [Re: Guitar Jones] #2454175
02/19/18 10:26 PM
02/19/18 10:26 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
propane torch and a wire brush or wheel. heat up small area then hit it with a wire brush.
perception is 90% of reality
Re: Best way to clean seam sealer from drip rails [Re: Guitar Jones] #2454202
02/19/18 10:53 PM
02/19/18 10:53 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Depends on the condition. Sometimes its totally dried out and cracking. That's when I'll basically chisel it out like mentioned above. If it's not as dried out, then I use heat.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Best way to clean seam sealer from drip rails [Re: Guitar Jones] #2454251
02/19/18 11:27 PM
02/19/18 11:27 PM
ky.
K
kenworth_goose Offline
K
ky.
I've had really good luck with lacquer thinner. Wipes right away.
