Originally Posted By RoadRunner
I had a piece of 1/2 x 1/8" stock that I ground down to fit into channel. I also ground a chisel point to get up and under the material. Just tapped it with a hammer and worked it down the channel. Then cleaned up with a stiff wire wheel.
Works like a charm!
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
