Best way to clean seam sealer from drip rails
#2453977
02/19/18 04:02 PM
02/19/18 04:02 PM
Guitar Jones
I have another roof for my 1st gen club cab that was cut at the pillars about 8 inches down. I need to get the sealer out of the drip rails so I can get the roof panels separated.
This stuff is like cement in there so not wanting to use a hammer and chisel I was wondering if anyone has a better/easier way of removing the sealer.
Re: Best way to clean seam sealer from drip rails
[Re: Guitar Jones]
#2453999
02/19/18 04:41 PM
02/19/18 04:41 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: Guitar Jones]
#2454004
02/19/18 04:50 PM
02/19/18 04:50 PM
Guitar Jones
I have a propane torch, don't have a wire wheel though.
[Re: Guitar Jones]
#2454073
02/19/18 07:01 PM
02/19/18 07:01 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I had a piece of 1/2 x 1/8" stock that I ground down to fit into channel. I also ground a chisel point to get up and under the material. Just tapped it with a hammer and worked it down the channel. Then cleaned up with a stiff wire wheel.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#2454121
02/19/18 08:44 PM
02/19/18 08:44 PM
Posts: 16,489 On the run…
BloFish
On the run…
I had a piece of 1/2 x 1/8" stock that I ground down to fit into channel. I also ground a chisel point to get up and under the material. Just tapped it with a hammer and worked it down the channel. Then cleaned up with a stiff wire wheel. Works like a charm!
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Guitar Jones]
#2454175
02/19/18 10:26 PM
02/19/18 10:26 PM
Posts: 4,923 new berlin wisconsin
Mr T2U
propane torch and a wire brush or wheel. heat up small area then hit it with a wire brush.
perception is 90% of reality
[Re: Guitar Jones]
#2454202
02/19/18 10:53 PM
02/19/18 10:53 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Depends on the condition. Sometimes its totally dried out and cracking. That's when I'll basically chisel it out like mentioned above. If it's not as dried out, then I use heat.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
