Page 3 of 5 1 2 3 4 5
Re: Ritter Block [Re: Biginchmopar] #2453224
02/17/18 10:13 PM
02/17/18 10:13 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
Couple more pics
9125BC6D-6227-4862-B2D9-C7BA4286F7AC.jpeg3BD589BD-302B-4D37-A31E-E0531E78EAF7.jpegF34DE03A-55AA-41E8-8130-030A8C1B9F08.jpeg
Re: Ritter Block [Re: Biginchmopar] #2453387
02/18/18 11:10 AM
02/18/18 11:10 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Thank you for sharing
68 Barracuda Formula S 340
Re: Ritter Block [Re: Biginchmopar] #2453440
02/18/18 01:16 PM
02/18/18 01:16 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Did you bolt a timing cover to it?
Set a head gasket and check if it would seal and if the water passages line up?
I would also screw studs in it and see if the heads can go on
I have witnessed Shilohs (whitedart) problems and hope yours is trouble free.
"Just a Bracket car dressed up like a streetcar"
Re: Ritter Block [Re: Biginchmopar] #2453442
02/18/18 01:21 PM
02/18/18 01:21 PM
Canada
onig Offline
onig  Offline
Canada
Curious, how did you check the lifter angles?
69 Dart
Re: Ritter Block [Re: onig] #2453502
02/18/18 03:52 PM
02/18/18 03:52 PM
Carson City, Nevada
Carson City, Nevada
I used some lifters and did some measurements. I’ll reconfirm these once I get them to the shop with the fixture that we use to do lifter bushings.
Re: Ritter Block [Re: Just-a-dart] #2453503
02/18/18 03:55 PM
02/18/18 03:55 PM
Carson City, Nevada
Carson City, Nevada
Not yet, but I will soon (timing cover)
Studs and heads yes, gasket no
Re: Ritter Block [Re: WHITEDART] #2453549
02/18/18 05:46 PM
02/18/18 05:46 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted By WHITEDART
On another note I'm not saying it's mandatory.. but I think bushing the lifters is a smart move with the way that he has drilled the oil Galley through the center of the lifter bore.. it's very easy to get in a situation where the lifter uncovers the oil Passage
I'm not familiar with these and this may be a dumb question, but if the lifter bores interrupt the galley 100% and you bush them and block the galley, how is the crank oiled? Right side conventional and left side drilled through the center?
Re: Ritter Block [Re: CMcAllister] #2453698
02/18/18 11:42 PM
02/18/18 11:42 PM
Carson City, Nevada
Carson City, Nevada
These blocks have priority oiling to the mains. The lifter bushings I’m going to use will have groves on the outside to pass excess oil by.
Re: Ritter Block [Re: Biginchmopar] #2454100
02/19/18 08:00 PM
02/19/18 08:00 PM
Kansas, Topeka
69 lawndart Offline
69 lawndart  Offline
Kansas, Topeka
That's what I did with mine.
Re: Ritter Block [Re: 69 lawndart] #2454142
02/19/18 09:18 PM
02/19/18 09:18 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I know that the OP's block is cast iron due to the unthreaded freeze plug ports and lack of sleeves. Is your block above aluminum?
If so that is so cool! I had always wanted an all aluminum small block Mopar!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Ritter Block [Re: RylisPro] #2454326
02/20/18 12:56 AM
02/20/18 12:56 AM
Kansas, Topeka
69 lawndart Offline
69 lawndart  Offline
Kansas, Topeka
Yes sir it is.
Re: Ritter Block [Re: Biginchmopar] #2454399
02/20/18 03:07 AM
02/20/18 03:07 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
With the Limited oil return on the Block if you're doing a wet sump I would also recommend external drain Backs from the head to the oil pan this enables air to come up so oil can go down in other locations
Let me ask this, wet sump, what about drilling holes from the cam tunnel valley to the crankshaft, I know, I know, windage, it's an issue but is it really on a deal were you're not looking for every last HP?
I believe on a wet sump I would do a lot more work on oil return. I'll do that on one of the engines I'm going to build because it will be wet sump. I will look into all options but putting hole into the cam tunel to the crankshaft area would help. It might also help to return oil from the valley even though it is open in the back.
I will keep you guys posted.
What about drilling a 1/4 inch hole next to each main saddle. That way any oil that drains back would be down the side of the main saddle and not splashing around too much. Would require holes drilled next to #2, #3, and #4 mains.
HAH.
Never mind, i see you already handled the oil drain issue. Treed again.
Old Geezer Racing
Re: Ritter Block [Re: SCATPACK 1] #2454423
02/20/18 05:30 AM
02/20/18 05:30 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
They certainly look better, the rear cap is markedly improved.
I have a couple of XR2 blocks for P7 heads, they're earlier blocks. Once I've recovered from a recent surgery, I'll be measuring them. I have a feeling the lifter bores are out of position, based on my initial inspections.
Alan Jones
Re: Ritter Block [Re: RylisPro] #2454630
02/20/18 04:12 PM
02/20/18 04:12 PM
Be careful of what you wish for tsk whistling work
N/A iron blocks, even super charged, will run faster than the same parts in a aluminum block in the 1/4 mile in the same car weighing the same shruggy
Re: Ritter Block [Re: Cab_Burge] #2454631
02/20/18 04:15 PM
02/20/18 04:15 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
But the car won’t weight the same. Lol.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Ritter Block [Re: pittsburghracer] #2454633
02/20/18 04:18 PM
02/20/18 04:18 PM
Certain heads up classes out here have minimum weights shruggy
Re: Ritter Block [Re: Cab_Burge] #2454637
02/20/18 04:26 PM
02/20/18 04:26 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....so you'd prefer not to put the weight where YOU want it?
Re: Ritter Block [Re: Cab_Burge] #2454643
02/20/18 04:51 PM
02/20/18 04:51 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Which means they make more power. Ive been told by engine guys that you need to "get after" an aluminum block combination more so than an iron block. And then there's the extra expense. Some of us have a finite budget and want to spread it around past one engine or one car.
Re: Ritter Block [Re: J_BODY] #2454860
02/20/18 11:52 PM
02/20/18 11:52 PM
The car I'm talking about had ballast on the front bumper with the aluminum block, they moved it from there and move it further back to keep the front to rear ratio % the same for traction, they had to add over 400 lbs. to the car make the minimum weights shruggy
I wish I could afford to build a car like that, but I'm not whiney
Re: Ritter Block [Re: Biginchmopar] #2455141
02/21/18 04:14 PM
02/21/18 04:14 PM
Carson City, Nevada
Carson City, Nevada
The reason I didn't go with Aluminum is bore size, I believe the Aluminum Ritter Block is limited to 4.120 bore.
Look at the main caps between mine and the aluminum block , the front is the same but the rest are different. Maybe a change for the better? Rear cap is way better now.
